| sparks69 |
| Posted: May 31 2003, 11:49 PM |
I just downloaded 1.5.4 p4 and installed it. I opened up a movie that was compiled using divx 5.05 and had some audio sync problems (movie was okay until I fast forward or jumped ahead - Created by xpmeg 5.0rc1???). I had saved the audio using no compression but when I went to resync it back using lame 3.93 I keep getting this error "VideoSourceAVI error: The source image format is not acceptable. (error code -2)" I recompiled the movie using divx 4.12 and had no problem resynving the audio. Is this due to divx 5.05. Thanks John
| sparks69 |
| Posted: Jun 1 2003, 03:01 PM |
Does anyone know what this error means? It is only with divx 5.05 files. I was under the impression that this version 1.5.4 p4 is compatible with divx 5.05
error: VideoSourceAVI error: The source image format is not acceptable. (error code -2)
I get this error when I try to do anything with these files. It works great with all others.
Thanks for any info |
