Can Not Drag And Drop Clips, Can no longer drag and drop clips 1.10.4
pipedragon
Posted: May 3 2014, 04:06 AM
I just installed 1.10.4. Since installation, I can no longer drag and drop clips into the main panel. I can open them only using the file menu. I've tried re-installing, with same result. Is there a setting/preference I'm missing? Thanks!
Tyler
Posted: May 3 2014, 08:36 AM
Nope, it works the same as always
Only thing I can think of is - if you're running it as administrator, then drag and drop from non-administrator programs (like explorer) doesn't work (security measure of windows)
1 replies since May 3 2014, 04:06 AM Track this topic | Email this topic | Print this topic
