Black Screen In Capture Avi, hr = 80004005
Daniel
Posted: Apr 13 2014, 02:02 AM
So I have an issue recording with my easycap, It was running perfectley then I unplugged the easy cap because I was done for awhile, came back later, plugged it back in, black screen, and I have tried everything to fix it, I reversed the changes I made before it wasnt working, ive tried everything I can think off and now its getting annoying
I noticed there was another thread with a similar issue from 2012 that wasnt resolved so I thought I would just ptovide some answers to things I seen on that to save you guys some time
The source option under the video tab is grayed out for me so I cant click that,
The device shows up correctley with (direct show)
I have the correct video standard selected for both my console and my games
I am getting a yellow dot in the log saying "CapDShow: Unable to transition filter graph to run state: hr = 80004005 ()"
UPDATE: the error listed was to do with me selecting the wrong audio source by accident, The hr = 80004005 error is now gone, however the black screen remains
raffriff42
Posted: Apr 13 2014, 06:30 AM
>so I thought I would just provide some answers to things I seen on that to save you guys some time
A link to the actual thread would save everybody some time..
Did you see this
The problem most people are having is that it doesn't "display video correctly". After installing it, it should be recognized as a Syntek STK1160. You'll need to change the video from PAL to NTSC (If you live in America or Japan). Go to Control Panel -> Scanners and Cameras -> and right click on "Syntek STK1160" and select "Video Decoder Property". Change it from "PAL_B" (Or whatever it is) to "NTSC_M" (for America) and "NTSC_M_J" for Japan. You'll know the right one when it says "Signal Detected: 1".
Daniel
Posted: Apr 13 2014, 12:02 PM
QUOTE (raffriff42 @ Apr 13 2014, 06:30 AM)
Did you see this
http://forums.virtualdub.org/index.php?act...hl=black+screen Theres a link to the thread sorry, also I dont think its a device issues since the device will work both the software it came with and AMcap, plus for me I am pal_I and I already have that changed
raffriff42
Posted: Apr 13 2014, 12:14 PM
OK thanks for the link, now everyone can catch up. Others around here have more knowledge in this area - but first, what about this
QUOTE (phaeron @ Nov 5 2012, 07:55 PM)
Do you have any interesting errors showing up in the log (Capture | Log, F8)? These would be of the form: CapDShow: failed to build filter graph: ....
Daniel
Posted: Apr 13 2014, 12:23 PM
QUOTE (raffriff42 @ Apr 13 2014, 12:14 PM)
The log is showing no errors even when I start a capture test, it says connected to device successfully, and the capture was completed successfully
Also I tried capturing a video and playing the file, the saved captures come up also with a black screen, however the sound is being captured
raffriff42
Posted: Apr 13 2014, 04:07 PM
What software are you using the play the file? To eliminate any possible Windows codec issues, try VLC player.
What does VirtualDub File Information say? (please click the "copy" button and paste the report in your reply)
If the file is not AVI, or even if it is, please post a MediaInfo report too.
Daniel
Posted: Apr 13 2014, 06:52 PM
QUOTE (raffriff42 @ Apr 13 2014, 04:07 PM)
File information:
Video:
Frame size, fps (µs per frame): 720x576, 29.970 fps (33367 µs)
Length: 243 frames (0:08.10)
Decompressor: Internal DIB decoder (YUY2)
Number of key frames: 0
Min/avg/max/total key frame size: (no key frames)
Min/avg/max/total delta size: 0/590506/829440 (140130K)
Data rate: 141580 kbps (0.00% overhead)
Audio:
Sampling rate: 48000Hz
Channels: 2 (Stereo)
Sample precision: 16-bit
Compression: PCM (Uncompressed)
Layout: 5 chunks (0.00s preload)
Length: 304800 samples (0:06.35)
Min/avg/max/total frame size: 170624/243840/262144 (1191K)
Data rate: 1536 kbps (0.01% overhead)
Mediainfo:
General
Complete name                            : C:\Users\[USERNAME]\Documents\blank.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 138 MiB
Duration                                 : 8s 108ms
Overall bit rate                         : 143 Mbps
Video
Format                                   : YUV
Codec ID                                 : YUY2
Codec ID/Info                            : YUV 4:2:2 as for UYVY but with different component ordering within the u_int32 macropixel
Duration                                 : 8s 108ms
Bit rate                                 : 142 Mbps
Width                                    : 720 pixels
Height                                   : 576 pixels
Display aspect ratio                     : 5:4
Frame rate                               : 29.970 fps
Standard                                 : PAL
Color space                              : YUV
Chroma subsampling                       : 4:2:2
Compression mode                         : Lossless
Bits/(Pixel*Frame)                       : 11.391
Stream size                              : 137 MiB (99%)
Audio
Format                                   : PCM
Format settings, Endianness              : Little
Format settings, Sign                    : Signed
Codec ID                                 : 1
Duration                                 : 6s 350ms
Bit rate mode                            : Constant
Bit rate                                 : 1 536 Kbps
Channel(s)                               : 2 channels
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Stream size                              : 1.16 MiB (1%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 49 ms (1.46 video frame)
I have played the file with both windows media player and real player
Posted: Apr 13 2014, 07:52 PM
Did you verify via the Video-menu > Video source, if the right input is selected (Video Tuner / Video Composite / Video SVideo) ?
The fact that in Video-menu > Source... is greyed out, is normal.
This option is only active when "Screen capture" has been selected in the Device-menu.
Daniel
Posted: Apr 13 2014, 09:27 PM
QUOTE (Abrazo @ Apr 13 2014, 07:52 PM)
for Video source I always set it to composite the correct one for me, same setting I have on other applications
raffriff42
Posted: Apr 13 2014, 09:53 PM
Codec ID : YUY2
By a roundabout method, I ended up here: http://www.fourcc.org/yuv.php.
Which pointed me to this page: How do I play back AVIs with YUY2 video?
YUY2 is a raw video format that is often supported by video capture hardware and DirectDraw drivers. If you have a system which has support for the format both at the capture and display ends, though, it is still sometimes the case that you can't play videos in YUY2 back without getting an error along the lines of "Unknown compression" or "Codec not found".
Solution: Install Indeo 4.1 codec and add
vidc.YUY2=ir41_32.ax
under the '[Drivers32]' section in C:\windows\system.ini.
C:\windows\system.ini? OK it's an old page, but it sounds like a good idea to try to locate an Indeo 4.1 codec.
A quick Google search takes me here (sevenforums.com).
A little googling led me to the Ligos Corporation who now supply them. However, the Ligos site says that Indeo codecs are not supported for use with Vista or Win 7. [link added]
(digging around again, it seems free-codecs.com is the place to get the Indeo codec. It's linked from Wikipedia, it must be OK!!
...back to the sevenforums.com page, here is how to install it:
open a 'command prompt' using a rightclick, select, 'Run as Administrtor'
type: cd C:\Windows\SysWOW64 (32bit users can skip this step) - press enter
type: regsvr32 ir50_32.dll - press enter
...as an afterthought wacko.gif , I think you should simply
Get the VirtualDub FFmpeg input driver.
Chances are it will open the file.
This post has been edited by raffriff42 on Apr 13 2014, 10:07 PM
Daniel
Posted: Apr 13 2014, 11:43 PM
QUOTE (raffriff42 @ Apr 13 2014, 09:53 PM)
Codec ID : YUY2
Weird, I have no idea why but I actually already have that Indeo already installed, I tried the codecs anyway, no luck, I tried the command prompt you suggested, still no luck, The capture avi is still black with audio working along with the videos, so no change
raffriff42
Posted: Apr 14 2014, 12:37 AM
Repeat:
VLC player.
Daniel
Posted: Apr 14 2014, 01:50 AM
QUOTE (raffriff42 @ Apr 14 2014, 12:37 AM)
Repeat:
VLC player.
I have both of those installed but Im not sure what you are asking me to do, Attempting to use the capture card with virtualdub with the plugin in it, still black screen, while recording: black screen, after recording, the file has a black screen, this is on both vlc and virtualdub with and without FFmpeg input.
raffriff42
Posted: Apr 14 2014, 02:22 AM
I am suggesting you play the file that you say is all black, first with VLC player and then with VirtualDub+FFmpeg as per the link.
I think the file may be OK, & your PC is not playing it out correctly. You need to test for this possibility, at least.
Posted: Apr 14 2014, 04:58 PM
Are you really sure that there actually is an output-signal onto that composite cable ?
Do you have possibility to plug it into a television and verify if you really "see" the images.
Only when you are sure of that, you will still have to look for the problem at your easycap and computer's side.
If you do not get a 'preview' in VirtualDub capture mode, chances are very low that the capture itself will be succesfull.
16 replies since Apr 13 2014, 02:02 AM Track this topic | Email this topic | Print this topic
Pages: (2) [1] 2
