| Damian Clarck |
| Posted: Dec 2 2013, 05:57 PM |
When I set "export"->"image sequence", and select output format as JPEG, an error message appears "output settings must be 16/24/32-bit RGB, uncompressed in order to save a TARGA, JPEG or PNG sequence." Earlier, I set"video-->"direct stream mode", so i don`t need to select "uncompressed", and select "color depth 24 bit RGB" Could someone help me please?
| Posted: Dec 2 2013, 09:24 PM |
Most video is in a YUV format, so you'll need full processing mode, uncompressed video, and on the video menu->color depth=24bit rgb
