Why Is Virtualdub So Broken?
Track
Posted: Sep 24 2013, 03:46 PM
I'm having the same problem I've always had.
I'm trying to combine a few videos into one. I choose the first, append the rest, select direct stream copy and save as .AVI.
Sometimes, this works fine.
Today, it's not working at all.
I've tried it about two dozen times, because usually it ends up working eventually.
No matter what I've tried, at some point the counter stops and it gets stuck on a certain frame.
Could be any frame.. 38, 178, 254, 482, etc. The highest I've gotten was 803.
So, I have to ask - why is this piece of software so broken, and.. is there any other program I use to append videos?
Thanks.
Posted: Sep 24 2013, 04:04 PM
Works fine for everyone else
More likely to be a problem with the video you have or your hardware
I assume you've checked your windows event logs for any error messages
possible reasons could be
a damaged video file
a dodgy codec
bad sectors on your hard drive
for direct stream copying, virtualdub just reads the file off disk frame by frame and writes it out again
there isn't really anything to go wrong from virtualdub's end as long as it can read and write to a drive ok, and the files ok
Track
Posted: Sep 24 2013, 08:59 PM
The video files is a Lagarith encode done by VideoMach. I've used the exact same encoding technique over a dozen times with no issues.
I've also re-encoded the video files and VirtualDub still gets stuck.
a dodgy codec
Lagarith is not dodgy.
It's a new SSD.
Posted: Sep 24 2013, 09:28 PM
Lagarith's fine, I use it 24/7 here
(some old versions had a few bugs though)
Apart from that, all I can say is that if virtualdub was broken in such a basic way as you describe, complaints would fill the board
They don't though, so it would suggest an issue at your end
Try AviDemux and see if that works for you?
http://fixounet.free.fr/avidemux/
3 replies since Sep 24 2013, 03:46 PM Track this topic | Email this topic | Print this topic
