Select Video -> FrameRate -> "Change so video and audio durations match (29.970 fps)" get crash when starting conversion. Doesn't happen if specify the frame rate manually as 29.970 (for this particular WAV).
Am I bothered? Not in the least. Awesome product, thanks guys.
VirtualDub crash report -- build 32842 (release) --------------------------------------
Disassembly: 040d3680: 00e8 add al, ch 040d3682: 2a11 sub dl, [ecx] 040d3684: 0000 add [eax], al 040d3686: 46 inc esi 040d3687: 3bf3 cmp esi, ebx 040d3689: 7ee5 jle 040d3670 040d368b: 5e pop esi 040d368c: 83fb3f cmp ebx, 3fh 040d368f: 5b pop ebx 040d3690: 7d0c jge 040d369e 040d3692: b808000000 mov eax, 00000008 040d3697: 33c9 xor ecx, ecx 040d3699: e912110000 jmp 040d47b0 040d369e: c3 ret 040d369f: cc int 3 040d36a0: 53 push ebx 040d36a1: 55 push ebp 040d36a2: 56 push esi 040d36a3: 8b742410 mov esi, [esp+10h] 040d36a7: 57 push edi 040d36a8: b820000000 mov eax, 00000020 040d36ad: b9b6010000 mov ecx, 000001b6 040d36b2: 8bd6 mov edx, esi 040d36b4: e8f7100000 call 040d47b0 040d36b9: 8b5c241c mov ebx, [esp+1ch] 040d36bd: 8b4b14 mov ecx, [ebx+14h] 040d36c0: b802000000 mov eax, 00000002 040d36c5: e8e6100000 call 040d47b0 040d36ca: 33ed xor ebp, ebp 040d36cc: 33d2 xor edx, edx 040d36ce: 396b28 cmp [ebx+28h], ebp 040d36d1: 7643 jbe 040d3716 040d36d3: 8b4e0c mov ecx, [esi+0ch] 040d36d6: b800000080 mov eax, 80000000 040d36db: d3e8 shr eax, cl 040d36dd: 094608 or [esi+08h], eax 040d36e0: 8d4101 lea eax, [ecx+01h] 040d36e3: 89460c mov [esi+0ch], eax 040d36e6: 83f820 cmp eax, 20h 040d36e9: 7225 jc 040d3710 040d36eb: 8b4e08 mov ecx, [esi+08h] 040d36ee: 894c2414 mov [esp+14h], ecx 040d36f2: 8b442414 mov eax, [esp+14h] 040d36f6: 0fc8 bswap eax 040d36f8: 89442414 mov [esp+14h], eax 040d36fc: 8b4610 mov eax, [esi+10h] 040d36ff: 8b4c2414 mov ecx, [esp+14h] 040d3703: 8908 mov [eax], ecx <-- FAULT 040d3705: 83461004 add dword ptr [esi+10h], 04h 040d3709: 83460ce0 add dword ptr [esi+0ch], 0e0h 040d370d: 896e08 mov [esi+08h], ebp 040d3710: 42 inc edx 040d3711: 3b5328 cmp edx, [ebx+28h] 040d3714: 72bd jc 040d36d3 040d3716: ff460c inc dword ptr [esi+0ch] 040d3719: 837e0c20 cmp dword ptr [esi+0ch], 20h 040d371d: 722f jc 040d374e 040d371f: 8b5608 mov edx, [esi+08h] 040d3722: 89542414 mov [esp+14h], edx 040d3726: 8b442414 mov eax, [esp+14h] 040d372a: 0fc8 bswap eax 040d372c: 89442414 mov [esp+14h], eax 040d3730: 8b4610 mov eax, [esi+10h] 040d3733: 8b4c2414 mov ecx, [esp+14h] 040d3737: 8908 mov [eax], ecx 040d3739: bf04000000 mov edi, 00000004 040d373e: 017e10 add [esi+10h], edi 040d3741: 896e08 mov [esi+08h], ebp 040d3744: bde0ffffff mov ebp, ffffffe0 040d3749: 016e0c add [esi+0ch], ebp 040d374c: eb08 jmp 040d3756 040d374e: bde0ffffff mov ebp, ffffffe0 040d3753: 8d7d24 lea edi, [ebp+24h] 040d3756: 8b4e0c mov ecx, [esi+0ch] 040d3759: ba00000080 mov edx, 80000000 040d375e: d3ea shr edx, cl 040d3760: 8d4101 lea eax, [ecx+01h] 040d3763: 89460c mov [esi+0ch], eax 040d3766: 095608 or [esi+08h], edx 040d3769: 83f820 cmp eax, 20h 040d376c: 7227 jc 040d3795 040d376e: 8b4608 mov eax, [esi+08h] 040d3771: 89442414 mov [esp+14h], eax 040d3775: 8b442414 mov eax, [esp+14h] 040d3779: 0fc8 bswap eax 040d377b: 89442414 mov [esp+14h], eax 040d377f: 8b db 8bh
Built on Aegis on Fri Dec 24 13:18:44 2010 using compiler version 1400
Windows 6.1 (Windows Vista x86 build 7601) [Service Pack 1]
EAX = 09643000 EBX = 03710f80 ECX = ffffffff EDX = 00e17efd EBP = 00000000 ESI = 09d1ec70 EDI = 03710f80 ESP = 09d1ebb4 EIP = 040d3703 EFLAGS = 00010246 FPUCW = 027f FPUTW = aaaa
Crash context: An out-of-bounds memory access (access violation) occurred in module 'xvidcore'...
...writing address 09643000...
...while compressing frame 29 from 09830020 to 09480020 using codec "Xvid MPEG-4 Codec" (w32videocodecpack.cpp:696)...
...while running thread "Processing" (thread.cpp:163).
Pointer dumps:
EBX 03710f80: 0000001e 0000fffe 00000000 0000018e 00003454 00000001 00000004 00000000 ESI 09d1ec70: 000001b6 5001bffc ffffffff 00000020 09643000 09480020 00000000 00000000 EDI 03710f80: 0000001e 0000fffe 00000000 0000018e 00003454 00000001 00000004 00000000 ESP 09d1ebb0: 040d36ca 03710f80 03710a00 09d1ec70 03710e00 04119fa1 ffffffff 03710a00 09d1ebd0: 03710f80 00000001 00000004 03710a00 03710f80 03710e00 03710ac0 03710acc 09d1ebf0: 03710ae4 03710afc 00100000 00000001 09d1ecd4 03713740 03710a00 00000001 09d1ec10: 00000001 00000000 00000001 00000000 0000001e 00000000 00000000 00000000
Thread call stack: 040d3703: xvidcore!00003703 04119fa1: xvidcore!xvid_plugin_ssim [040d0000+42b90+7411] 0411b1e0: xvidcore!xvid_plugin_ssim [040d0000+42b90+8650] 0411c24b: xvidcore!xvid_encore [040d0000+4c220+2b] 10002241: xvidvfw!00002241 100087a7: xvidvfw!DriverProc [10000000+8550+257] 7731ce14: ntdll!bsearch [772c0000+5cdae+66] 7731d14a: ntdll!bsearch [772c0000+5cdae+39c] 7731ce14: ntdll!bsearch [772c0000+5cdae+66] 7731d14a: ntdll!bsearch [772c0000+5cdae+39c] 7731d0fc: ntdll!bsearch [772c0000+5cdae+34e] 7731d2dd: ntdll!RtlHashUnicodeString [772c0000+5d1e1+fc] 7731d3ca: ntdll!RtlHashUnicodeString [772c0000+5d1e1+1e9] 77317670: ntdll!RtlFindActivationContextSectionString [772c0000+5759b+d5] 773179e8: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+35b] 77317a4b: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+3be] 773178e4: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+257] 7731794f: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+2c2] 773178e4: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+257] 77317d87: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+6fa] 77317d87: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+6fa] 77318e20: ntdll!LdrGetDllHandleEx [772c0000+58b19+307] 77317cf7: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+66a] 77318da6: ntdll!LdrGetDllHandleEx [772c0000+58b19+28d] 773170f2: ntdll!RtlRunOnceBeginInitialize [772c0000+56fef+103] 77318d8b: ntdll!LdrGetDllHandleEx [772c0000+58b19+272] 7731ce14: ntdll!bsearch [772c0000+5cdae+66] 7731d14a: ntdll!bsearch [772c0000+5cdae+39c] 7731d0fc: ntdll!bsearch [772c0000+5cdae+34e] 7731d2dd: ntdll!RtlHashUnicodeString [772c0000+5d1e1+fc] 7731d3ca: ntdll!RtlHashUnicodeString [772c0000+5d1e1+1e9] 77317670: ntdll!RtlFindActivationContextSectionString [772c0000+5759b+d5] 773179e8: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+35b] 77317a4b: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+3be] 773178e4: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+257] 7731794f: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+2c2] 77317d87: ntdll!RtlDosApplyFileIsolationRedirection_Ustr [772c0000+5768d+6fa] 77318e20: ntdll!LdrGetDllHandleEx [772c0000+58b19+307] 005c07c7: ValidateScopeTableHandlers() 005c0961: _ValidateEH3RN() 772df817: ntdll!RtlGetGroupSecurityDescriptor [772c0000+1f6a4+173] 005b4f91: _except_handler3() 773071b9: ntdll!RtlRaiseStatus [772c0000+47105+b4] 7730718b: ntdll!RtlRaiseStatus [772c0000+47105+86] 772c6051: ntdll!wcsspn [772c0000+5e2f+222] 772c6032: ntdll!wcsspn [772c0000+5e2f+203] 7731f9e8: ntdll!LdrGetProcedureAddressEx [772c0000+5f881+167] 7732002d: ntdll!RtlGetActiveActivationContext [772c0000+5feb9+174] 77307017: ntdll!KiUserExceptionDispatcher [772c0000+47008+f] 77305574: ntdll!NtContinue [772c0000+45568+c] 77307025: ntdll!KiUserExceptionDispatcher [772c0000+47008+1d] 755eb760: KERNELBASE!RaiseException [755e0000+b70c+54] 77315da4: ntdll!_wcsnicmp [772c0000+558fc+4a8] 77315dd3: ntdll!_wcsnicmp [772c0000+558fc+4d7] 755eb760: KERNELBASE!RaiseException [755e0000+b70c+54] 77315da4: ntdll!_wcsnicmp [772c0000+558fc+4a8] 77315dd3: ntdll!_wcsnicmp [772c0000+558fc+4d7] 77312fe7: ntdll!RtlAllocateHeap [772c0000+52dd6+211] 6fd61759: MSVFW32!ICSendMessage [6fd60000+1728+31] 6fd64de8: MSVFW32!ICCompress [6fd60000+4d85+63] 0057e3fb: VDVideoCompressorVCM::PackFrameInternal() 0057ee15: VDVideoCompressorVCM::CompressFrame() 755e17c4: KERNELBASE!WaitForSingleObjectEx [755e0000+1730+94] 7707baf3: kernel32!WaitForSingleObjectEx [77030000+4bab0+43] 004783d2: VDThreadedVideoCompressor::ProcessFrame() 00478807: VDThreadedVideoCompressor::ExchangeBuffer() 004220e9: VDDubVideoProcessor::WriteFinishedVideoFrame() 00422f89: VDDubVideoProcessor::ProcessVideoFrame() 00423137: VDDubVideoProcessor::WriteVideo() 00425533: VDStreamInterleaver::GetNextAction() 004207f9: VDDubProcessThread::ThreadRun() 004023b7: ?$VDProtectedAutoScope1::?$VDProtectedAutoScope1() 005190d2: VDThread::StaticThreadStart() 005b808e: _callthreadstartex() 005b8133: _threadstartex@4() 77083c45: kernel32!BaseThreadInitThunk [77030000+53c33+12] 773237f5: ntdll!RtlInitializeExceptionChain [772c0000+63706+ef] 773237c8: ntdll!RtlInitializeExceptionChain [772c0000+63706+c2]
-- End of report
