Virtualdub 1.9.11 Crashing Constantly
MithosKuu
Posted: Aug 8 2013, 01:43 PM
VirtualDub version 1.9.11 (32 bit) keeps crashing before I can even start recording. I am using a Gigaware VHS to DVD capture device on Windows 8 64 bit.
I start up VirtualDub, select File>Capture AVI, I can mess with settings just fine, for now I'm using defaults. As soon as I turn on the console that is hooked up to my capture device VirtualDub will crash if I try messing with inputs or start recording. I get no video preview even if I enabled it before turning on the console.
VirtualDub crash report -- build 32842 (release)
Disassembly:
77c43e20: 008945b0894d    add    [ecx+4d89b045], cl
77c43e26: ac              lodsb
77c43e27: 85c9            test   ecx, ecx
77c43e29: 0f8550010000    jnz    77c43f7f
77c43e2f: 803d08a2d07700  cmp    byte ptr [77d0a208], 00h
77c43e36: 0f852f0cfeff    jnz    77c24a6b
77c43e3c: 8b4710          mov    eax, [edi+10h]
77c43e3f: 33db            xor    ebx, ebx
77c43e41: 381d08a0d077    cmp    [77d0a008], bl
77c43e47: 8d7710          lea    esi, [edi+10h]
77c43e4a: 0f95c3          setnz  bl
77c43e4d: 8945bc          mov    [ebp-44h], eax
77c43e50: 4b              dec    ebx
77c43e51: 81e3c8a1d077    and    ebx, 77d0a1c8
77c43e57: 85c0            test   eax, eax
77c43e59: 0f84dd010000    jz     77c4403c
77c43e5f: 833fff          cmp    dword ptr [edi], 0ffh
77c43e62: 0f841839ffff    jz     77c37780
77c43e68: 8b5704          mov    edx, [edi+04h]
77c43e6b: f6c201          test   dl, 01h
77c43e6e: 0f8527700000    jnz    77c4ae9b
77c43e74: 8b7508          mov    esi, [ebp+08h]
77c43e77: 90              nop
77c43e78: 8bca            mov    ecx, edx
77c43e7a: 2bce            sub    ecx, esi
77c43e7c: 8bc2            mov    eax, edx
77c43e7e: 8d7704          lea    esi, [edi+04h]
77c43e81: f0              lock
77c43e82: 0fb10e          cmpxchg ecx, [esi]
77c43e85: 8b7508          mov    esi, [ebp+08h]
77c43e88: 3bc2            cmp    eax, edx
77c43e8a: 0f85ff6f0000    jnz    77c4ae8f
77c43e90: 8b07            mov    eax, [edi]
77c43e92: 33f6            xor    esi, esi
77c43e94: c745b400000000  mov    dword ptr [ebp-4ch], 00000000
77c43e9b: 83f8ff          cmp    eax, 0ffh
77c43e9e: 7403            jz     77c43ea3
77c43ea0: ff4014          inc    dword ptr [eax+14h]      <-- FAULT
77c43ea3: b98203fe7f      mov    ecx, 7ffe0382
77c43ea8: 803900          cmp    byte ptr [ecx], 00h
77c43eab: ba22170000      mov    edx, 00001722
77c43eb0: 0f8514770500    jnz    77c9b5ca
77c43eb6: 8b45bc          mov    eax, [ebp-44h]
77c43eb9: 53              push   ebx
77c43eba: 6a00            push   00h
77c43ebc: 83f8ff          cmp    eax, 0ffh
77c43ebf: 0f844f770500    jz     77c9b614
77c43ec5: 50              push   eax
77c43ec6: e85d9d0000      call   77c4dc28
77c43ecb: 3d02010000      cmp    eax, 00000102
77c43ed0: 0f844f770500    jz     77c9b625
77c43ed6: 85c0            test   eax, eax
77c43ed8: 0f8815780500    js     77c9b6f3
77c43ede: 837dac00        cmp    dword ptr [ebp-54h], 00h
77c43ee2: 0f8535010000    jnz    77c4401d
77c43ee8: 8b4df8          mov    ecx, [ebp-08h]
77c43eeb: 5f              pop    edi
77c43eec: 5e              pop    esi
77c43eed: 33cd            xor    ecx, ebp
77c43eef: b802000000      mov    eax, 00000002
77c43ef4: 5b              pop    ebx
77c43ef5: e816b90000      call   77c4f810
77c43efa: 8be5            mov    esp, ebp
77c43efc: 5d              pop    ebp
77c43efd: c20400          ret    0004
77c43f00: 8b01            mov    eax, [ecx]
77c43f02: 83f8ff          cmp    eax, 0ffh
77c43f05: 0f84fdfdffff    jz     77c43d08
77c43f0b: 83780800        cmp    dword ptr [eax+08h], 00h
77c43f0f: 0f85f3fdffff    jnz    77c43d08
77c43f15: f7c600000002    test   esi, 02000000
77c43f1b: 0f              db     0fh
77c43f1c: 8528            test   [eax], ebp
77c43f1e: 49              dec    ecx
77c43f1f: fe              db     0feh
Built on Aegis on Fri Dec 24 13:18:44 2010 using compiler version 1400
Windows 6.1 (Windows Vista x64 build 7600) []
EAX = 00000000
EBX = 00000000
ECX = fffffffc
EDX = 00000000
EBP = 0018f714
ESI = 00000000
EDI = 04080cf8
ESP = 0018f6b0
EIP = 77c43ea0
EFLAGS = 00010213
FPUCW = 027f
FPUTW = ffff
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'ntdll'...
...writing address 00000014.
Pointer dumps:
EDI   04080cf8: 00000000 fffffffc 00000000 00000000 00000514 00000000 00000000 00000000
ESP   0018f6b0: 00000001 00000000 00000000 00000008 00000000 7ffdd000 00000000 00000000
     0018f6d0: 00000514 00000514 0018f6d8 00000002 00000050 00000008 74765322 00000050
     0018f6f0: 00000000 067e1c60 002b9fc0 00000000 00000000 0018f750 77559b03 6a55244b
     0018f710: 00000000 0018f744 77c43d7f 00000004 04080cf8 04080cf4 00000000 0018fb08
EBP   0018f710: 00000000 0018f744 77c43d7f 00000004 04080cf8 04080cf4 00000000 0018fb08
     0018f730: 00000000 00000000 00000004 7ffdd000 067e2420 0018f750 77c43d9b 04080cf8
     0018f750: 00000000 5688cfc5 04080cf8 4cce87b5 02c4c654 02c4c648 0018f790 002b9fc0
     0018f770: 0018fb08 5696c588 ffffffff 5f60b5b8 04080cf8 02c4c648 5f60a8dd 02b9682c
Thread call stack:
77c43ea0: ntdll!wcsspn [77c20000+23c05+29b]
74765322: AcLayers!GetHookAPIs [74750000+26dc+12c46]
77559b03: msvcrt!free [77550000+9aca+39]
77c43d7f: ntdll!wcsspn [77c20000+23c05+17a]
77c43d9b: ntdll!wcsspn [77c20000+23c05+196]
5688cfc5: VSFilter!DirectVobSub [56860000+28710+48b5]
5f60b5b8: qedit!DllCanUnloadNow [5f5b0000+a2a0+51318]
5f60a8dd: qedit!DllCanUnloadNow [5f5b0000+a2a0+5063d]
5f60a691: qedit!DllCanUnloadNow [5f5b0000+a2a0+503f1]
5fc5f378: quartz!DllGetClassObject [5fc40000+5b48+19830]
5fc61f61: quartz!DllGetClassObject [5fc40000+5b48+1c419]
7599c780: KERNELBASE!GetModuleHandleExW [75990000+c6f6+8a]
5fc4ab1d: quartz!DllGetClassObject [5fc40000+5b48+4fd5]
77559b9c: msvcrt!malloc [77550000+9b45+57]
5fc6c834: quartz!DllGetClassObject [5fc40000+5b48+26cec]
5fc6c854: quartz!DllGetClassObject [5fc40000+5b48+26d0c]
5fc66047: quartz!DllGetClassObject [5fc40000+5b48+204ff]
00590503: ?A0x1d32a578::DestroySubgraph()
77a48af6: USER32!PostMessageW [77a40000+8aa8+4e]
5fc5790e: quartz!DllGetClassObject [5fc40000+5b48+11dc6]
5fc4ebe5: quartz!DllGetClassObject [5fc40000+5b48+909d]
5fc4511d: quartz!DllCanUnloadNow [5fc40000+4067+10b6]
5fc4828a: quartz!DllGetClassObject [5fc40000+5b48+2742]
5fc5fd70: quartz!DllGetClassObject [5fc40000+5b48+1a228]
5fc4ed14: quartz!DllGetClassObject [5fc40000+5b48+91cc]
77c4ddf4: ntdll!NtReleaseMutant [77c20000+2dde8+c]
7599103b: KERNELBASE!ReleaseMutex [75990000+102b+10]
5fc5fbf9: quartz!DllGetClassObject [5fc40000+5b48+1a0b1]
5fcc5f90: quartz!AMGetErrorTextW [5fc40000+79385+cc0b]
00593c95: VDCaptureDriverDS::TearDownGraph()
77a4787a: USER32!gapfnScSendMessage [77a40000+72f8+582]
77a47933: USER32!gapfnScSendMessage [77a40000+72f8+63b]
77a478f4: USER32!gapfnScSendMessage [77a40000+72f8+5fc]
77a47b6f: USER32!PeekMessageW [77a40000+7983+1ec]
77a47bf0: USER32!PeekMessageW [77a40000+7983+26d]
74b7173b: uxtheme!GetThemeTransitionDuration [74b60000+102b1+148a]
77a47c44: USER32!PeekMessageW [77a40000+7983+2c1]
77c4dc44: ntdll!NtCallbackReturn [77c20000+2dc38+c]
77a47c57: USER32!PeekMessageW [77a40000+7983+2d4]
74b6162a: uxtheme!0000162a
77c62c92: ntdll!KiUserCallbackDispatcher [77c20000+42c64+2e]
0059804d: VDCaptureDriverDS::DisplayDriverDialog()
0049376b: _catch$?OnCommand@VDCaptureProjectUI@@IAE_NI@Z$0()
77a48d35: USER32!GetWindowLongW [77a40000+8d07+2e]
77a48d41: USER32!GetWindowLongW [77a40000+8d07+3a]
77a47e67: USER32!IsWindow [77a40000+7cd3+194]
77a48fed: USER32!GetAncestor [77a40000+8e40+1ad]
74b62957: uxtheme!00002957
74b87538: uxtheme!GetBufferedPaintDC [74b60000+26f42+5f6]
74b6284a: uxtheme!0000284a
74b616e1: uxtheme!000016e1
74b617af: uxtheme!000017af
77a475e7: USER32!gapfnScSendMessage [77a40000+72f8+2ef]
77a476f5: USER32!gapfnScSendMessage [77a40000+72f8+3fd]
77a48f8c: USER32!GetAncestor [77a40000+8e40+14c]
004794a0: VDUIFrame::DefProc()
00490580: VDCaptureProjectUI::CommonWndProc()
00493efd: VDCaptureProjectUI::MainWndProc()
0048cbdd: VDCaptureProjectUI::WndProc()
00479b65: VDUIFrame::StaticWndProc()
77a477d8: USER32!gapfnScSendMessage [77a40000+72f8+4e0]
77a478cb: USER32!gapfnScSendMessage [77a40000+72f8+5d3]
77a4899d: USER32!GetKeyboardLayout [77a40000+8061+93c]
77a65f38: USER32!PeekMessageA [77a40000+25dbc+17c]
77a4ef74: USER32!DispatchMessageA [77a40000+ef65+f]
00452596: WinMain@16()
005b78db: __tmainCRTStartup()
7588850d: KERNEL32!BaseThreadInitThunk [75860000+284ff+e]
77c7bf39: ntdll!RtlInitializeExceptionChain [77c20000+5beb4+85]
77c7bf0c: ntdll!RtlInitializeExceptionChain [77c20000+5beb4+58]
-- End of report
Posted: Aug 9 2013, 07:03 PM
I don't know if it can help, but does it make a difference when you first connect and start your capturing device before activating VirtualDub and its "capture mode" ?
Also do verify if you installed a 32-bit driver for your capturing device. Normally 32-bit VirtualDub should work with 32-bit drivers, codecs and filters.
To verify if it has something to do with the audio- and/or video-codecs that you are using, you could try to open a random file in VirtualDub and recompress it.
If the codecs do not give a problem in editing mode, they should evenso give no problem when used in capture mode.
For what concerns your crash report, sorry myself I have no experience with that.
1 replies since Aug 8 2013, 01:43 PM Track this topic | Email this topic | Print this topic
