Suddenly Error Message With Vd 1.7.8
Mobilias
Posted: May 13 2013, 06:26 PM
Hey,
I´ve got a Win7x86 system processing videos with virtualdub 1.7.8 without problems. A few days ago suddenly I got the following error message: "VirtualDub Error Couldn't locate decompressor for format 'DX50' (unknown); VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable."
What might have happen? I tried to de- and reinstall VD and ffdshow rev. 2946 – but no change. sad.gif
If I try VD on my Virtual Windows XP-machine I even get the same error message!
Has anybody an idea how to solve this problem?
Thanks for all help!
Mobilias
Posted: May 13 2013, 07:31 PM
In the ffdshow vfw config, look at the decoders page and check that dixv is not 'disabled'
Mobilias
Posted: May 13 2013, 08:34 PM
In the ffdshow vfw config at the decoders page I found following informations:
Format: DivX 4/5/6; Decoder Xvid
DivX 3; libavcodec
Posted: May 13 2013, 09:19 PM
Well, that looks normal then
Just checking here, but the version of ffdshow and virtualdub is the same ? (32 bit versions of both, or 64 bit versions of both)
You tried reinstalling ffdshow ?
How does your registry look
eg. my working system
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32]
or if 64bit windows
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows NT\CurrentVersion\Drivers32]
"msacm.msgsm610"="msgsm32.acm"
"msacm.msg711"="msg711.acm"
"msacm.l3acm"="C:\\Windows\\SysWOW64\\l3codeca.acm"
"vidc.yuy2"="msyuv.dll"
"vidc.i420"="iyuv_32.dll"
"vidc.cvid"="iccvid.dll"
"vidc.yvyu"="msyuv.dll"
"vidc.yvu9"="tsbyuv.dll"
"wavemapper"="msacm32.drv"
"midimapper"="midimap.dll"
"vidc.uyvy"="msyuv.dll"
"msacm.imaadpcm"="imaadp32.acm"
"msacm.msadpcm"="msadp32.acm"
"vidc.iyuv"="iyuv_32.dll"
"vidc.mrle"="msrle32.dll"
"vidc.msvc"="msvidc32.dll"
"wave"="wdmaud.drv"
"midi"="wdmaud.drv"
"mixer"="wdmaud.drv"
"aux"="wdmaud.drv"
"wave5"="wdmaud.drv"
"mixer5"="wdmaud.drv"
"midi5"="wdmaud.drv"
"msacm.ac3acm"="AC3ACM.acm"
"msacm.lameacm"="LameACM.acm"
"msacm.aacacm"="AACACM.acm"
"vidc.x264"="C:\\PROGRA~2\\x264vfw\\x264vfw.dll"
"VIDC.LAGS"="lagarith.dll"
"VIDC.FFDS"="ff_vfw.dll"
"wave1"="wdmaud.drv"
"midi1"="wdmaud.drv"
"mixer1"="wdmaud.drv"
"wave2"="wdmaud.drv"
"midi2"="wdmaud.drv"
"mixer2"="wdmaud.drv"
"wave3"="wdmaud.drv"
"midi3"="wdmaud.drv"
"mixer3"="wdmaud.drv"
"wave4"="wdmaud.drv"
"midi4"="wdmaud.drv"
"mixer4"="wdmaud.drv"
"vidc.yv12"="xvidvfw.dll"
"vidc.DX50"="xvidvfw.dll"
Mobilias
Posted: May 14 2013, 12:29 PM
Well, there are a few differences. But I don´t know if they are faults.
Perhaps you can check it up?
Schlüsselname: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows NT\CurrentVersion\Drivers32
Klassenname: <KEINE KLASSE>
Letzter Schreibzugriff: 06.05.2013 - 14:49
Wert 0
Typ: REG_SZ
Daten: msrle32.dll
Wert 1
Typ: REG_SZ
Daten: msvidc32.dll
Wert 2
Typ: REG_SZ
Daten: imaadp32.acm
Wert 3
Typ: REG_SZ
Daten: msg711.acm
Wert 4
Typ: REG_SZ
Daten: msgsm32.acm
Wert 5
Typ: REG_SZ
Daten: msadp32.acm
Wert 6
Typ: REG_SZ
Daten: midimap.dll
Wert 7
Typ: REG_SZ
Daten: msacm32.drv
Wert 8
Typ: REG_SZ
Daten: msyuv.dll
Wert 9
Typ: REG_SZ
Daten: msyuv.dll
Wert 10
Typ: REG_SZ
Daten: msyuv.dll
Wert 11
Typ: REG_SZ
Daten: iyuv_32.dll
Wert 12
Typ: REG_SZ
Daten:
Wert 13
Typ: REG_SZ
Daten: tsbyuv.dll
Wert 14
Typ: REG_SZ
Daten: C:\Windows\SysWOW64\l3codeca.acm
Wert 15
Typ: REG_SZ
Daten: iccvid.dll
Wert 16
Typ: REG_SZ
Daten: tsccvid.dll
Wert 17
Typ: REG_SZ
Daten: C:\PROGRA~2\COMMON~1\ULEADS~1\vio\dvacm.acm
Wert 18
Typ: REG_SZ
Daten: DivX.dll
Wert 19
Typ: REG_SZ
Daten: pspgru.acm
Wert 20
Typ: REG_SZ
Daten: DivX.dll
Wert 21
Typ: REG_SZ
Daten: ff_vfw.dll
Wert 22
Typ: REG_SZ
Daten: wdmaud.drv
Wert 23
Typ: REG_SZ
Daten: wdmaud.drv
Wert 24
Typ: REG_SZ
Daten: wdmaud.drv
Wert 25
Typ: REG_SZ
Daten: wdmaud.drv
Wert 26
Typ: REG_SZ
Daten: wdmaud.drv
Wert 27
Typ: REG_SZ
Daten: wdmaud.drv
Wert 28
Typ: REG_SZ
Daten: wdmaud.drv
Wert 29
Typ: REG_SZ
Daten: wdmaud.drv
Wert 30
Typ: REG_SZ
Daten: wdmaud.drv
Wert 31
Typ: REG_SZ
Daten: wdmaud.drv
Wert 32
Typ: REG_SZ
Daten: wdmaud.drv
Wert 33
Typ: REG_SZ
Daten: wdmaud.drv
Wert 34
Typ: REG_SZ
Daten: wdmaud.drv
Wert 35
Typ: REG_SZ
Daten: wdmaud.drv
Wert 36
Typ: REG_SZ
Daten: wdmaud.drv
Wert 37
Typ: REG_SZ
Daten: wdmaud.drv
Wert 38
Typ: REG_SZ
Daten: wdmaud.drv
Wert 39
Typ: REG_SZ
Daten: wdmaud.drv
Wert 40
Typ: REG_SZ
Daten: wdmaud.drv
Mobilias
Posted: May 25 2013, 10:03 AM
can anybody help me on, please? It´s so frustating with this error message. sad.gif
Posted: May 25 2013, 10:35 AM
Please verify if DivX.dll is in C:\Windows\system32.
Eventually re-install the DivX codec via 'Install free software' on http://www.divx.com.
If DivX codec is available for VirtualDub, you should see it via Video-menu > Compression...
Mobilias
  Posted: May 25 2013, 03:05 PM
Hi Abrazo,
1. DivX.dll isn't in C:\Windows\system32
2. DivX-Codec has already been installed. I reinstalled the complete package with player etc.
4. The DivX-codec is not to be seen in VD Video-menu > Compression
Posted: May 25 2013, 03:16 PM
sorry, I thought I'd replied to this already
there looks like there is an error in your registry
in the 'daten' part of each, there should be some information
blank entries can cause errors
eg, this one
Wert 12
Typ: REG_SZ
Daten:
export the entire key section, and then delete the vidc.i420 entry, and see if you're ok after a reboot
re:
On a 64bit os, the 32bit dll will actually be in c:\windows\syswow64
Mobilias
  Posted: May 25 2013, 04:43 PM
hey super! I deleted the vidc.i420 entry and now everything works again.
You did a very good job!
A lot of thanks to you!!!
9 replies since May 13 2013, 06:26 PM Track this topic | Email this topic | Print this topic
