| johnsonlam |
| Posted: Feb 7 2013, 07:36 PM |
Working on a video already in UT codec, disable all other filters, and the last one "Smart Resize" seems trigger the crash ...
1) Windows 7 64bit / 10GB RAM 1) UT Codec 12.0 (ULRG) 2) Smart Resize (1.1)
Processing Settings VirtualDub.audio.SetSource(1); VirtualDub.audio.SetMode(1); VirtualDub.audio.SetInterleave(1,500,1,0,-400); VirtualDub.audio.SetClipMode(1,1); VirtualDub.audio.SetEditMode(1); VirtualDub.audio.SetConversion(0,0,0,0,0); VirtualDub.audio.SetVolume(); VirtualDub.audio.SetCompression(); VirtualDub.audio.EnableFilterGraph(0); VirtualDub.video.SetInputFormat(0); VirtualDub.video.SetOutputFormat(7); VirtualDub.video.SetMode(3); VirtualDub.video.SetSmartRendering(0); VirtualDub.video.SetPreserveEmptyFrames(0); VirtualDub.video.SetFrameRate2(0,0,1); VirtualDub.video.SetIVTC(0, 0, 0, 0); VirtualDub.video.SetCompression(0x67726c75,0,10000,0); VirtualDub.video.SetCompData(4,"BAEAAA=="); VirtualDub.video.filters.Clear(); VirtualDub.video.filters.Add("Camcorder color denoise 1.4 SSE2"); VirtualDub.video.filters.instance[0].Config(38); VirtualDub.video.filters.Add("smart resize (1.1)"); VirtualDub.video.filters.instance[1].Config(640,512,0,4,640,512,0x000000,"1 1 1 4 320 240 90 0 0 1 1 16 16 2 2"); VirtualDub.video.filters.Add("MSU Denoiser 2.5.1"); VirtualDub.video.filters.instance[2].ConfigAuto(0, 1, 60, 0); VirtualDub.audio.filters.Clear();
Dump (a part of, too long): Crash reason: Access Violation
Crash context: An out-of-bounds memory access (access violation) occurred in module 'Resize'...
...reading address 0C240000...
...while running filter "smart resize (1.1)" (FilterInstance.cpp:2198)...
...while configuring filter "smart resize (1.1)" (FilterInstance.cpp:928).
Pointer dumps:
EDI 02dc0808: 00000000 00000000 00000000 00000000 fffffbcf 0000130e 000034bd fffffc66 ESP 0018e2e8: 0c23f600 02dba740 00000280 02dc2f60 0c23f600 0c240000 00000000 03c6649c 0018e308: 02dc3854 0c23f5f4 02dbef50 00000008 00000001 00000000 00000002 00000001 0018e328: 00000000 027cc5de 00011c71 00000000 0bc14700 024dee50 0018e388 02dba740 0018e348: 03c66795 02dc2f60 0c23f600 00000280 024ded00 024ded00 00000000 1a7b9611
VirtualDub.project.ClearTextInfo(); |
| Posted: Feb 7 2013, 08:00 PM |
Yup the smart resize filter crashes Since it's from 2001 I don't think you'll see it fixed
You might try the 'force single framebuffer' setting Select the filter in your list, then click the options button and tick the box
If that doesn't help then you're out of luck
| johnsonlam |
| Posted: Feb 7 2013, 11:54 PM |
| QUOTE (dloneranger @ Feb 7 2013, 08:00 PM) | Yup the smart resize filter crashes Since it's from 2001 I don't think you'll see it fixed
If that doesn't help then you're out of luck | It's works! Thanks for your advise |
