Virtualdub Player Stops Playing
TCmullet
Posted: Nov 12 2012, 01:49 PM
I've never seen this happen, but I don't try often. I pressed the Play button on a 2 hour video. It stops at frame 152175 (1:41:27.000). My video is 25.000 fps. No amount of re-pressing the play button will get it to play. But if I press Stop, then I can re-press Play and it appears to resume playing where it left off. (At least I hope it does.)
Fwiw, I'm using Vdub 1.10.2 build 34807
The input is an AviSynth script running MultiDecimate pass 1. (This requires you play the whole video essentially non-stop for it to properly create it's output file.)
Posted: Nov 19 2012, 05:43 AM
This happens in one of two ways: either the UI gets out of sync and thinks the video is playing when it isn't, or the rendering engine is actually "playing" but is frozen. The two can be distinguished by whether the menus switched over. I thought I fixed the outstanding bugs in this area, but if you can get a repro case for this I can look at it again.
1 replies since Nov 12 2012, 01:49 PM Track this topic | Email this topic | Print this topic
