| Korwin |
| Posted: Sep 6 2012, 09:45 PM |
"No audio decompressor could be found to decompress the source audio format (source format tag: 00ff)".
VirtualDub 1.9.11 VirtualDub.exe MD5 Hash: bafd24e8bd9d6a0cdb347809d4a68093 SHA1 Hash: ef31b38c1811da6f4397a74e531c37975fe8a9e2 SHA256 Hash: BE79194E70798BEDF5F113D523700C66CDF9CD4734A04C663FF0E34D35A11F4C Size in bytes: 2670592 Size in kilobytes: 2608 Last written to: 24.12.2010 13:18:46
General Format: MPEG-4 Format profile: Base Media / Version 2 Codec ID: mp42 File size: 189 MiB Duration: 4mn 16s Overall bit rate mode: Variable Overall bit rate: 6 161 Kbps Encoded date: UTC 2012-07-24 01:31:58 Tagged date: UTC 2012-07-24 01:31:58 gsst: 0 gstd: 257066 gssd: B4A7DA0A3HH1346966702031543 gshh: r9---ham02s04.c.youtube.com
Video ID: 1 Format: AVC Format/Info: Advanced Video Codec Format profile: High@L4.0 Format settings, CABAC: Yes Format settings, ReFrames: 1 frame Codec ID: avc1 Codec ID/Info: Advanced Video Coding Duration: 4mn 16s Bit rate: 5 966 Kbps Maximum bit rate: 9 087 Kbps Width: 1 920 pixels Height: 1 080 pixels Display aspect ratio: 16:9 Frame rate mode: Constant Frame rate: 25.000 fps Color space: YUV Chroma subsampling: 4:2:0 Bit depth: 8 bits Scan type: Progressive Bits/(Pixel*Frame): 0.115 Stream size: 183 MiB (97%) Tagged date: UTC 2012-07-24 01:31:59
Audio ID: 2 Format: AAC Format/Info: Advanced Audio Codec Format profile: LC Codec ID: 40 Duration: 4mn 16s Bit rate mode: Variable Bit rate: 192 Kbps Maximum bit rate: 202 Kbps Channel(s): 2 channels Channel positions: Front: L R Sampling rate: 44.1 KHz Compression mode: Lossy Stream size: 5.88 MiB (3%) Title: IsoMedia File Produced by Google, 5-11-2011 Encoded date: UTC 2012-07-24 01:31:59 Tagged date: UTC 2012-07-24 01:31:59 Source: http://www.youtube.com/watch?v=PxFfSbIafy0&hd=1
Windows 7 x64 |
| Korwin |
| Posted: Sep 6 2012, 09:53 PM |
Release build - 1.10.2 (experimental), 64-bit (x64) version - "The file (...) is of an unknown or unsupported file type".
File Path: Veedub64.exe MD5 Hash: 92f758ff17f4e02029ff9270841f9962 SHA1 Hash: d62f085c0a872c91cdbf6891758bb3770386f96d SHA256 Hash: 6734027DAEBBDFCC0D29641BCAF79F7C82351BE83B3A1E555449327FD1F8A6E0 Size in bytes: 4016128 Size in kilobytes: 3922 Last written to: 03.06.2012 14:29:20
File Path: vdub64.exe MD5 Hash: 1c53ff221e09075e54f1faab1034e0d3 SHA1 Hash: 0cf43f07170981f8e41c63d812b1a930a110d43c SHA256 Hash: CEE751A769908111F113D45737130621B5CA3E574FE98B00E39F6B62997F52A6 Size in bytes: 9728 Size in kilobytes: 9,5 Last written to: 03.06.2012 14:28:46 |
| ale5000 |
| Posted: Sep 6 2012, 11:55 PM |
Look here: http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488
You need the QuickTime plugin by fccHandler to open mp4 files and the AAC acm codec to decode the AAC audio.
PS: If you use the 32-bit VirtualDub you need the 32-bit version of plugins and codecs instead if you use the 64-bit VirtualDub you need the 64-bit version of plugins and codecs.
