| fvisagie |
| Posted: Aug 18 2012, 03:24 PM |
When dubbing is in progress with VDXA enabled, pressing Ctrl-Alt-Del (to get to the Lock this computer / Switch user / Log off... screen) crashes VirtualDub. This happens whether input/output panes are visible or not, or whether the status window has been enabled or not.
The error message is:
VirtualDub Error The 3D accelerator is no longer available.
Disabling VDXA prevents this from happening.
VirtualDub 1.9.11 and Windows 7 32-bit Professional SP1, 2.6GHz Intel Core i5-2540M with 4GB RAM.
VirtualDub configuration: VirtualDub.audio.SetSource(1); VirtualDub.audio.SetMode(0); VirtualDub.audio.SetInterleave(1,500,1,0,0); VirtualDub.audio.SetClipMode(1,1); VirtualDub.audio.SetConversion(0,0,0,0,0); VirtualDub.audio.SetVolume(); VirtualDub.audio.SetCompression(); VirtualDub.audio.EnableFilterGraph(0); VirtualDub.video.SetInputFormat(0); VirtualDub.video.SetOutputFormat(15); VirtualDub.video.SetMode(1); VirtualDub.video.SetSmartRendering(0); VirtualDub.video.SetPreserveEmptyFrames(1); VirtualDub.video.SetFrameRate2(0,0,1); VirtualDub.video.SetIVTC(0, 0, 0, 0); VirtualDub.video.SetCompression(0x7367616c,0,10000,0); VirtualDub.video.SetCompData(1,"AA=="); VirtualDub.video.filters.Clear(); VirtualDub.audio.filters.Clear(); |
| Posted: Aug 18 2012, 08:15 PM |
This is normal. VirtualDub 1.9.11 uses Direct3D 9, which blocks the application from using the 3D accelerator when a desktop mode switch occurs. This causes all of VirtualDub's frame buffers on the graphics card to be lost and forces the processing run to be terminated.
1.10.2 and above can use Direct3D 9Ex on Windows Vista and above, which allows usage of the GPU to continue in the background. There is unfortunately no workaround available for Windows XP. |
| fvisagie |
| Posted: Aug 19 2012, 02:49 PM |
Thanks for the explanation, appreciated. |
