Rfe: Option "maintain Aspect Ratio", Request for enhancement
belonesox
  Posted: Jun 26 2012, 04:29 PM
Hello all.
I propose request for enhancement, "Maintain Aspect Ratio Mode",
probably under menu "View/Pane Layout", or obligate "View/Auto Size panes" maintain aspect ratio while resizing.
My problem — when I open AVISynth scripts is not possible to preview with correct aspect ratio (with square pixels),
activating/deactivating "View/Auto Size panes" does nothing.
May be there exists another workaround for the problem?
Waiting for the answers,
Sincerely, Stas Fomin
levicki
Posted: Jun 29 2012, 02:39 PM
QUOTE (belonesox @ Jun 26 2012, 05:29 PM)
Hello all.
If you know the aspect ratio that is the output of your script (for example 16:9) you can right-click view pane and select 16:9 from the menu. After doing that, resizing the view pane will keep proper aspect. Same goes for other values (yes, even 1:1).
1 replies since Jun 26 2012, 04:29 PM Track this topic | Email this topic | Print this topic
