This happened with 1.10.1. So I got 1.10.2 and still happened.
Using internal resize to resize from 1248x704 (hufyuv) to 850x480 (hufyuv). Encoding finishes. Playing the resultant file in WMP gives black and white image. Loading in 1.10.2 gives this crash immediately:
| CODE | VirtualDub crash report -- build 34807 (release) --------------------------------------
Disassembly: 10006420: 0475 add al, 75h 10006422: f0 lock 10006423: 03f3 add esi, ebx 10006425: 3bf5 cmp esi, ebp 10006427: 72e5 jc 1000640e 10006429: 5b pop ebx 1000642a: 5e pop esi 1000642b: 5d pop ebp 1000642c: c3 ret 1000642d: 8d4900 lea ecx, [ecx+00h] 10006430: 1000 adc [eax], al 10006432: 1000 adc [eax], al 10006434: 0000 add [eax], al 10006436: 0000 add [eax], al 10006438: 800080 add byte ptr [eax], 80h 1000643b: 0080008000ff add [eax-ff8000], al 10006441: 00ff add bh, bh 10006443: 00ff add bh, bh 10006445: 00ff add bh, bh 10006447: 0000 add [eax], al 10006449: 2000 and [eax], al 1000644b: 0000 add [eax], al 1000644d: 2000 and [eax], al 1000644f: 00854a000085 add [ebp-7affffb6], al 10006455: 4a dec edx 10006456: 0000 add [eax], al 10006458: 0000 add [eax], al 1000645a: 1333 adc esi, [ebx] 1000645c: 0000 add [eax], al 1000645e: 1333 adc esi, [ebx] 10006460: 77f3 ja 10006455 10006462: fc cld 10006463: e577 in eax, 77h 10006465: f3fc cld 10006467: e58d in eax, 8dh 10006469: 40 inc eax 1000646a: 0000 add [eax], al 1000646c: 8d4000 lea eax, [eax+00h] 1000646f: 005657 add [esi+57h], dl 10006472: 8b442418 mov eax, [esp+18h] 10006476: 8b742414 mov esi, [esp+14h] 1000647a: 8b7c2410 mov edi, [esp+10h] 1000647e: ba30640010 mov edx, 10006430 10006483: 8d4ef8 lea ecx, [esi-08h] 10006486: 2bf0 sub esi, eax 10006488: 8da42400000000 lea esp, [esp+00] 1000648f: 8da42400000000 lea esp, [esp+00] 10006496: 8da42400000000 lea esp, [esp+00] 1000649d: 8d4900 lea ecx, [ecx+00h] 100064a0: 0f6e06 movd mm0, [esi] <-- FAULT 100064a3: 0f6e6e04 movd mm5, [esi+04h] 100064a7: 0f7fc1 movq mm1, mm0 100064aa: 0fdb4210 pand mm0, [edx+10h] 100064ae: 0f7fec movq mm4, mm5 100064b1: 0f71d108 psrlw mm1, 08h 100064b5: 0fdb6210 pand mm4, [edx+10h] 100064b9: 0f7fea movq mm2, mm5 100064bc: 0f71d508 psrlw mm5, 08h 100064c0: 0ff902 psubw mm0, [edx] 100064c3: 0f6e7608 movd mm6, [esi+08h] 100064c7: 0f71d208 psrlw mm2, 08h 100064cb: 0ff922 psubw mm4, [edx] 100064ce: 0ffdd1 paddw mm2, mm1 100064d1: 0f71d608 psrlw mm6, 08h 100064d5: 0ff94a08 psubw mm1, [edx+08h] 100064d9: 0ffdf5 paddw mm6, mm5 100064dc: 0f73f220 psllq mm2, 20h 100064e0: 0ff96a08 psubw mm5, [edx+08h] 100064e4: 0f61c2 punpcklwd mm0, mm2 100064e7: 0f73f620 psllq mm6, 20h 100064eb: 0ff54220 pmaddwd mm0, [edx+20h] 100064ef: 0f61e6 punpcklwd mm4, mm6 100064f2: 0ffdc9 paddw mm1, mm1 100064f5: 0ff56220 pmaddwd mm4, [edx+20h] 100064f9: 0ffded paddw mm5, mm5 100064fc: 0ffdca paddw mm1, mm2 100064ff: 0ffe4218 paddd mm0, [edx+18h] 10006503: 0ffdee paddw mm5, mm6 10006506: 0f7fca movq mm2, mm1 10006509: 0ffe6218 paddd mm4, [edx+18h] 1000650d: 0f7fcb movq mm3, mm1 10006510: 0f7fee movq mm6, mm5 10006513: 0ff54a28 pmaddwd mm1, [edx+28h] 10006517: 0f7fef movq mm7, mm5 1000651a: 0ffec8 paddd mm1, mm0 1000651d: 0f db 0fh 1000651e: f5 cmc 1000651f: 6a db 6ah
Built on Althena on Sun Jun 03 14:28:23 2012 using compiler version 1400
Windows 5.1 (Windows XP x86 build 2600) [Service Pack 3] Memory status: virtual free 1986M/2048M, commit limit 5985M, physical total 2046M
EAX = 000006a4 EBX = 00000d48 ECX = 01cf00f8 EDX = 10006430 EBP = 01db73a0 ESI = 01cefa5c EDI = 01c8c2fc ESP = 0012f8f0 EIP = 100064a0 EFLAGS = 00210216 FPUCW = ffff027f FPUTW = ffffaaaa
Crash context: An out-of-bounds memory access (access violation) occurred in module 'huffyuv'...
...reading address 01CEFA5C...
...while decompressing video frame 0 (VideoSource.cpp:2149)...
...while using input buffer at 00c36ef0-00c62837 (VideoSource.cpp:2148)...
...while using output buffer at 01b60080-01cee783 (VideoSource.cpp:2147).
Pointer dumps:
ECX 01cf00f8: 80108010 80108010 80108010 80108010 80108010 80108010 80108010 80108010 EDX 10006430: 00100010 00000000 00800080 00800080 00ff00ff 00ff00ff 00002000 00002000 EDI 01c8c2f8: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ESP 0012f8f0: 01b60080 01cf0020 100044b7 01cf0020 01b60080 01db73a0 000006a4 0012f970 0012f910: 0012f970 0012f958 00c27520 00000003 00000002 003e8a78 1000116b 0012f970 0012f930: 00000018 75a8b500 75a71938 003e8a78 00000001 0000400d 0012f970 00000018 0012f950: 00c368b0 00c367c0 0012f988 75a74df4 75a8b500 0000400d 0012f970 00000018 EBP 01db73a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 01db73c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 01db73e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 01db7400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Thread call stack: 100064a0: huffyuv!DriverProc [10000000+1000+54a0] 100044b7: huffyuv!DriverProc [10000000+1000+34b7] 1000116b: huffyuv!DriverProc [10000000+1000+16b] 75a71938: MSVFW32!ICSendMessage [75a70000+190d+2b] 75a74df4: MSVFW32!ICDecompress [75a70000+4db7+3d] 005cf851: VDVideoDecompressorVCM::DecompressFrame() 004f7a93: VideoSourceAVI::streamGetFrame() 0043b830: VDFilterFrameVideoSource::RunRequests() 7c9101db: ntdll!RtlAllocateHeap [7c900000+100c4+117] 005e4bc6: malloc() 00471148: VDProject::UpdateFrame() 0043aa85: VDFilterFrameRequest::CreateClient() 0043aacd: VDFilterFrameRequest::CreateClient() 00439a32: VDFilterFrameManualSource::CreateRequest() 00447680: FilterSystem::RequestFrame() 00473084: VDProject::DisplayFrame() 00470648: VDProject::MoveToFrame() 0047551b: VDProject::Open() 0051f4eb: VDAutoLogger::VDAutoLogger() 004616ac: OpenAVI() 0047e831: VDProjectUI::MenuHit() 7e419488: USER32!GetWindowLongA [7e410000+945d+2b] 7e428d8b: USER32!DefWindowProcW [7e410000+18d20+6b] 0048c7d0: VDUIFrame::DefProc() 0047fe67: _catch$?MainWndProc@VDProjectUI@@IAEJIIJ@Z$0() 7e419488: USER32!GetWindowLongA [7e410000+945d+2b] 00475f40: VDProjectUI::WndProc() 0048ce85: VDUIFrame::StaticWndProc() 7e418734: USER32!GetDC [7e410000+86c7+6d] 7e418816: USER32!GetDC [7e410000+86c7+14f] 7e4189cd: USER32!GetWindowLongW [7e410000+88a6+127] 7e42a43b: USER32!PeekMessageA [7e410000+1a340+fb] 7e4196c7: USER32!DispatchMessageA [7e410000+96b8+f] 0045fe46: WinMain@16() 005e9586: __tmainCRTStartup() 7c817077: kernel32!RegisterWaitForInputIdle [7c800000+1702e+49]
-- End of report
