| icelancer |
| Posted: May 3 2012, 06:26 AM |
When I use VirtualDub 1.9.11, I cannot load captured videos (AVI format) from Camtasia Recorder. I get the title error - 'tscc' codec not available. I've installed the latest version of tscc codecs and ffdshow with no luck.
Googling a bit, I downloaded a very old version of vdub, 1.6.19. Works perfectly.
What's the deal? What changed? Why can't I use the new versions? |
| Posted: May 3 2012, 12:57 PM |
Dunno, I can use tscc with the latest version without problem
By any chance were the newer versions you tried the 64bit versions? (64bit virtualdub can only use 64bit codecs)
| icelancer |
| Posted: May 4 2012, 01:17 AM |
That would be the problem. Thanks! |
