| rfmmars |
| Posted: Feb 14 2012, 12:12 AM |
When I go to open, say 2000 segmented serial jpeg files, nothing shows in the folder, only if I do *.* enter does the files appear and load correctly.
Richard |
| Posted: Feb 14 2012, 06:19 AM |
On the Open File dialog, change the 'Files Of Type' to 'image sequence' and it'll show the jpgs
| Posted: Feb 20 2012, 10:13 PM |
Strange, they should show up. Are you seeing *.jpg;*.jpeg show up in the All Files filter list? |
