How To Make Vd Use Sar/par And Dar Informations
rmanal
Posted: Jan 15 2012, 10:38 AM
Hello,
I have a DV file with size 720x480 but with SAR: 3/2, PAR: 8/9, DAR=PAR*SAR:4/3.
But when I open it in VD it displays a 720*480 file with square pixel: so how to tell VD to use SAR and PAR informations instead of resizing the file with another method inducing a degradation of the quality?
Thank you
Rmanal
stephanV
Posted: Jan 15 2012, 10:41 AM
You can't. Signalling DAR/PAR is up to the codec. You will have to set this manually when you export in the codec settings..
useful links:
rmanal
Posted: Jan 15 2012, 05:12 PM
OK thank you. It could be an improvement as this information is essential in the visualization of the video.
Nevertheless I don't how to set it manually: could you give me an exemple please, with one codec?
Thank you
stephanV
Posted: Jan 15 2012, 07:24 PM
It is not possible to make it because VirtualDub does not control codec settings.
Depends on what codec you are using.
useful links:
rmanal
Posted: Jan 16 2012, 06:30 PM
For codec exemple, DIVX?
stephanV
Posted: Jan 16 2012, 08:26 PM
Video Tab > Format Out
useful links:
rmanal
Posted: Jan 18 2012, 07:35 AM
OK but in a DV file we have SAR= 3/2, PAR= 8/9. And in this video tab we can only set a PAR. So how to also set the SAR in order to retrieve a correct 4/3 file format?
Thank you
stephanV
Posted: Jan 18 2012, 05:27 PM
What you mean with SAR is just horizontal resolution divided by the vertical resolution. There is no reason to explicitly set that.
useful links:
rmanal
Posted: Jan 21 2012, 10:22 AM
SAR is the stockage aspect ratio, in the case of DV it is equal to 1.5: if you don't take it into account how to retrieve a 4/3 ratio?
stephanV
Posted: Jan 21 2012, 01:45 PM
That value isn't storedin DV either. Again, it's horizontal devided by vertical resolution. (720/480=1.5)
useful links:
rmanal
Posted: Jan 21 2012, 07:01 PM
OK I have said a stupid thing.
Thank you for your help.
10 replies since Jan 15 2012, 10:38 AM Track this topic | Email this topic | Print this topic
