| knight5923 |
| Posted: Jan 12 2012, 06:32 PM |
I've been using virtualdub for quite some time now on WinXP with no trouble what-so-ever. However, I've recently updated to Windows 7, and since, have been receiving error messages while doing tasks that I performed perfectly well in XP. So here's what I'm doing:
I'm compressing a gaming video recorded using Fraps. I open the video, and select the DIVX codec for compression, as seen in this picture.
I then select "save as AVI" from the file menu, and as soon as it begins progressing, I receive an error message reading "Video compression error: The source image format is not acceptable. (error code -2)" Also pictured below. http://img215.imageshack.us/img215/5236/errordi.jpg
This is the exact same process I've used dozens of times before without issue, so I am at a bit of a loss regarding what the problem is and how to fix it. If anyone could provide any help or insight, I'd be extremely grateful.
Thanks for your time, Knight5923 |
| Abrazo |
| Posted: Jan 12 2012, 08:23 PM |
In the "Select video compression" dialogbox that you mention: - click on the Configure button (while the DivX codec is still selected in the list); - in the "Main"-tab, at Certification Profile choose "Home theater profile" or something higher (probably it is now set on "Mobile profile" which is not compatible with the resolution of your video file |
| evropej |
| Posted: Jan 12 2012, 09:30 PM |
Select the unrestricted profile in the divx settings, that setting probably got reset. |
| knight5923 |
Posted: Jan 12 2012, 09:50 PM |
Oh, I feel so stupid lol I can't believe I forgot to reset it to unconstrained. Thanks for the heads up folks, much appreciated! |
