| nomura |
| Posted: Dec 14 2011, 10:24 AM |
Hello,
Description: After a video driver update the virtualdub (v1.9.11) capture screen gone blank with sound, I still can capture and watch the captured video without problems.
Details: I have a ASUS M4A78 Pro with a AMD Phenon 9950 Quad Core, DDR2 8GB memory, on board ATI HD3200 graphics and Windows 7 64bit Ultimate. I was using the ATI driver version 8.850.0.0 from April 2011, it was upgraded to 8.911.0.0 November 2011 that is the last version.
I use a IEEE1394 card to capture from a CANOPUS ADVC-110, that uses a DVSD codec.
Soon after the update followed by a reboot, the capture mode in virtualdub display a screen like this: http://i1142.photobucket.com/albums/n608/s...dub-capture.png
Looks like an overlay issue?
I can hear the audio and capture fine, after the capture I can load the avi file on virtualdub or WMP without any display issue. Did some other tests with the directshow capture with VLC without problem.
Thank you. |
| nomura |
| Posted: Dec 20 2011, 06:03 AM |
Just to update the post, I've bought a new LED TV without a DVI connector, now I use the graphic card HDMI output instead. Without changing anything, the overlay at virtualdub got fixed, I can see the image just fine. |
