Input Plugin Progress Window Disappears
JPT
Posted: Jul 27 2011, 02:24 PM
not sure if this is a Virtualdub problem, or if it's located in fcchandlers plugin code.
Open any video file that triggers eg the mpeg or mkv input plugin.
Before virtualdub is actually startet, activate the explorer again.
This only works when vdub isn't in the cache yet, and harddisk activity is neccessary. Else the startup will be too fast.
Now if you click on the virtualdub Button in the taskbar, the vdub app is not locked (modal dialog?), as it should be.
The progress dialog is not visible. You get it, if minimizing all apps (or Desktop shortcut), then activating vdub again.
But virtualdub still is not locked. you may for example close vdub, which results in a crash.
Windows XP SP3
vdub 1.9.11
I will post a crash report, as soon as I am able to reproduce it again. Currently vdub is in cache and the startup is too fast.
JPT
Posted: Jul 28 2011, 03:01 PM
VirtualDub crash report -- build 32842 (release)
Disassembly:
00465000: 0474            add    al, 74h
00465002: 0e              push   cs
00465003: 8b5508          mov    edx, [ebp+08h]
00465006: 57              push   edi
00465007: 52              push   edx
00465008: e8c3cfffff      call   00461fd0
0046500d: 8bf0            mov    esi, eax
0046500f: eb02            jmp    00465013
00465011: 33f6            xor    esi, esi
00465013: 885dfc          mov    [ebp-04h], bl
00465016: 33db            xor    ebx, ebx
00465018: 3bf3            cmp    esi, ebx
0046501a: 7408            jz     00465024
0046501c: 8b06            mov    eax, [esi]
0046501e: 8b10            mov    edx, [eax]
00465020: 8bce            mov    ecx, esi
00465022: ffd2            call   edx
00465024: 8b4d08          mov    ecx, [ebp+08h]
00465027: 3bcb            cmp    ecx, ebx
00465029: 7407            jz     00465032
0046502b: 8b01            mov    eax, [ecx]
0046502d: 8b5004          mov    edx, [eax+04h]
00465030: ffd2            call   edx
00465032: 3bf3            cmp    esi, ebx
00465034: 897508          mov    [ebp+08h], esi
00465037: 7408            jz     00465041
00465039: 8b06            mov    eax, [esi]
0046503b: 8b10            mov    edx, [eax]
0046503d: 8bce            mov    ecx, esi
0046503f: ffd2            call   edx
00465041: 8b4f50          mov    ecx, [edi+50h]
00465044: 3bcb            cmp    ecx, ebx
00465046: 7407            jz     0046504f
00465048: 8b01            mov    eax, [ecx]
0046504a: 8b5004          mov    edx, [eax+04h]
0046504d: ffd2            call   edx
0046504f: 8d4f38          lea    ecx, [edi+38h]
00465052: 897750          mov    [edi+50h], esi
00465055: e886430100      call   004793e0
0046505a: 83c8ff          or     eax, 0ffh
0046505d: 899f80000000    mov    [edi+80], ebx
00465063: 899f84000000    mov    [edi+84], ebx
00465069: 898788000000    mov    [edi+88], eax
0046506f: 89878c000000    mov    [edi+8c], eax
00465075: 891df0f16300    mov    [0063f1f0], ebx
0046507b: 891df4f16300    mov    [0063f1f4], ebx
00465081: a3f8f16300      mov    [0063f1f8], eax
00465086: a3fcf16300      mov    [0063f1fc], eax
0046508b: 8b4f0c          mov    ecx, [edi+0ch]
0046508e: 3bcb            cmp    ecx, ebx
00465090: 7408            jz     0046509a
00465092: 8b01            mov    eax, [ecx]
00465094: 8b5018          mov    edx, [eax+18h]
00465097: 53              push   ebx
00465098: ffd2            call   edx
0046509a: 8b4f0c          mov    ecx, [edi+0ch]
0046509d: 8b01            mov    eax, [ecx]      <-- FAULT
0046509f: 8b501c          mov    edx, [eax+1ch]
004650a2: ffd2            call   edx
004650a4: b802000000      mov    eax, 00000002
004650a9: 398744010000    cmp    [edi+144], eax
004650af: 7c06            jl     004650b7
004650b1: 898744010000    mov    [edi+144], eax
004650b7: 8bcf            mov    ecx, edi
004650b9: e8b2c4ffff      call   00461570
004650be: 53              push   ebx
004650bf: 8bcf            mov    ecx, edi
004650c1: e8eac2ffff      call   004613b0
004650c6: 8b4f0c          mov    ecx, [edi+0ch]
004650c9: 8b01            mov    eax, [ecx]
004650cb: 8b5024          mov    edx, [eax+24h]
004650ce: ffd2            call   edx
004650d0: 8b4f0c          mov    ecx, [edi+0ch]
004650d3: 8b01            mov    eax, [ecx]
004650d5: 8b502c          mov    edx, [eax+2ch]
004650d8: ffd2            call   edx
004650da: 8b4f0c          mov    ecx, [edi+0ch]
004650dd: 8b01            mov    eax, [ecx]
004650df: 8b5028          mov    edx, [eax+28h]
004650e2: ffd2            call   edx
004650e4: 53              push   ebx
004650e5: 53              push   ebx
004650e6: 8bcf            mov    ecx, edi
004650e8: e8a3b9ffff      call   00460a90
004650ed: 8b4d08          mov    ecx, [ebp+08h]
004650f0: 3bcb            cmp    ecx, ebx
004650f2: c645fc01        mov    byte ptr [ebp-04h], 01h
004650f6: 7407            jz     004650ff
004650f8: 8b01            mov    eax, [ecx]
004650fa: 8b5004          mov    edx, [eax+04h]
004650fd: ffd2            call   edx
004650ff: 8b              db     8bh
Built on Aegis on Fri Dec 24 13:18:44 2010 using compiler version 1400
Windows 5.1 (Windows XP x86 build 2600) [Service Pack 3]
EAX = ffffffff
EBX = 00000000
ECX = 00000000
EDX = 002e0002
EBP = 0013fda4
ESI = 00c74c70
EDI = 00c69de0
ESP = 0013fd70
EIP = 0046509d
EFLAGS = 00210246
FPUCW = ffff027f
FPUTW = ffffffff
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'VirtualDub'...
...reading address 00000000.
Pointer dumps:
EDX   002e0002: 00000000 06030000 06040202 06050202 06060202 06070202 06080202 06090202
ESI   00c74c70: 005ea478 00000002 00c6eb78 00c69de0 00030006 010c0122 00439350 10006000
EDI   00c69de0: 005ec178 00bb0178 00000000 00000000 00000000 00000000 00000000 00000000
ESP   0013fd70: 00000001 00bb47c4 0013ff0c 00c6d5f8 00c6d66a 00c6d66a 00c69de0 0060c50c
     0013fd90: 0051d29e 0013fd70 0013fe58 005d4353 00000003 0013fe64 0044909b 00c74c70
     0013fdb0: 00000000 00000000 00c74c70 00000000 00000000 00000000 7e37a340 00000002
     0013fdd0: 00000001 00000000 7e368734 00cb0762 00000465 00000001 00000000 0059f070
EBP   0013fda0: 00000003 0013fe64 0044909b 00c74c70 00000000 00000000 00c74c70 00000000
     0013fdc0: 00000000 00000000 7e37a340 00000002 00000001 00000000 7e368734 00cb0762
     0013fde0: 00000465 00000001 00000000 0059f070 dcbaabcd 00000000 0013fe3c 0059f070
     0013fe00: 0013fe68 0060c990 7ffdf000 00c6bf18 00000000 00000002 7e368801 0013fef8
Thread call stack:
0046509d: VDProject::Open()
0051d29e: VDAutoLogger::VDAutoLogger()
0044909b: VDProcessCommandLine()
7e368734: USER32!GetDC [7e360000+86c7+6d]
7e36882a: USER32!GetDC [7e360000+86c7+163]
7e3689cd: USER32!GetWindowLongW [7e360000+88a6+127]
7e3693e9: USER32!PeekMessageW [7e360000+929b+14e]
7e37a471: USER32!PeekMessageA [7e360000+1a340+131]
7e3689ea: USER32!GetWindowLongW [7e360000+88a6+144]
7e37a43b: USER32!PeekMessageA [7e360000+1a340+fb]
004525a8: WinMain@16()
005b78db: __tmainCRTStartup()
7c817067: kernel32!RegisterWaitForInputIdle [7c800000+1701e+49]
-- End of report
Posted: Jul 31 2011, 11:31 PM
We're both at fault.
The problem is that in order for the progress dialog to properly block the UI, it needs to have a tag that references VirtualDub's window as the parent. The plugin doesn't do this, so the two windows are independent. However, this can't be fixed in the plugin because I don't pass the window handle to the API... so I'd need to fix that before the plugin can be fixed.
2 replies since Jul 27 2011, 02:24 PM Track this topic | Email this topic | Print this topic
