| JPT |
| Posted: Jul 21 2011, 11:10 AM |
I report this in case it was easy to fix and you care about it. I do not really need it to be fixed.
virtualdub says "audio display is disabled because the audio track is compressed". But the file is PCM...
Format: PCM Codec_ID: 00001000-0000-0100-8000-00AA00389B71 Codec: PCM Codec: PCM Codec_Family: PCM Codec_Info: Extensible wave format Codec_CC: FFFE
file was downmixed from dts using eac3to.
VD File info says uncompressed PCM (0xFFFE), 24 bit, 48 khz, stereo
thanks. |
| Posted: Jul 24 2011, 02:35 AM |
VirtualDub can't tell whether a format is compressed if it doesn't recognize the format, so it assumes that any format it doesn't know about is compressed. I should at least fix the message. |
