| Zilog |
Posted: Jan 8 2003, 05:23 PM |
Well, I haven't used VD for quite some time, and anyway I have a new install (new CPU/mobo & capture card )
Anyway: in the CAPTURE window: I make all my necessary settings (video/audio codecs, cropping settings, etc etc) and save the prefs as default... Then I exit VD...My settings should be saved for next time nope???! used to work like this!! Well, the only remembered setting is the audio compression....Manually reinputting everything each time really is a pain in the *ss
I tried clearing the regbase with AuxSetup, no change
This bug happened with 1.4.10 & 1.4.13...
Any idea? couldn't find a clue on all this forum |
| Zilog |
Posted: Jan 23 2003, 10:25 PM |
(BUMP)
Ok, no one seems to have the same problem or care about it
So I've finally mailed the poor Avery
sigh... |
