| chembot |
| Posted: Dec 29 2002, 10:08 AM |
I'm trying to delete about 5 seconds worth of frames in VirtualDub 1.4.13. I select the frames, delete them, then save the avi using direct stream copy for both audio and video. Even though it shows the frames gone in the preview window, when I play the file with media player, half of them are still there. Is this a known bug? |
| jcsston |
| Posted: Dec 29 2002, 05:11 PM |
Matroska Dev
You have to cut on keyframes when using 'direct stream copy'
