Runtime Library Error, crash after selecting video compression
mintenwi
Posted: Dec 29 2002, 02:59 AM
I unzipped the SW and used AuxSetup.exe to install the 'handler' (DLLs).
After loading any kind of AVI or MPG (can be previewed in virtualdub), and after selecting the menu [video], [Compression]; I always get an error message "Microsoft Visual C++ Runtime Library. C:/..../VirtualDub.exe. Abnormal Program Termination" . Appears in both releases 1.4.13 and 1.4.12.
jcsston
Posted: Dec 29 2002, 03:19 AM
Matroska Dev
What video codecs do you have installed.
Look at your 'system.ini' and under '[drivers32]' the lines that start with 'vidc' are the VFW video codecs.
Use the Matroska file format
mintenwi
Posted: Dec 29 2002, 09:17 PM
QUOTE (jcsston @ Dec 28 2002, 09:19 PM)
the only system.ini I've found is c:\winnt\system.ini, a very short one (copied below the line).
I have installed the DivX5.0.2 pro bundle, so I think there is at least one coder available.
Since I use WIN2000, I followed the instructions in the FAQ an looked in the registry in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32
There I found a whole bunch of vidc.xxxx, a small subset is copied below from a txt dump of the registry. In the past I indeed installed div3, div4, and recently div5:
Value 23
Type: REG_SZ
Data: DivXc32.dll
Value 24
Type: REG_SZ
Data: DivXc32f.dll
Value 25
Type: REG_SZ
Data: DivX.dll
So: What am I missing or doing wrong?
____________________________
; for 16-bit app support
msacm.g723=g723.acm
[drivers]
wave=mmdrv.dll
timer=timer.drv
[mci]
[driver32]
[386enh]
woafont=dosapp.FON
EGA80WOA.FON=EGA80WOA.FON
EGA40WOA.FON=EGA40WOA.FON
CGA80WOA.FON=CGA80WOA.FON
CGA40WOA.FON=CGA40WOA.FON
jcsston
Posted: Dec 29 2002, 09:31 PM
Matroska Dev
Well, I was thinking that you had a video codec installed that was causing VirtualDub to crash.
I'm running Win98SE so I'm not sure were to find a list of your installed codecs. Maybe Control Panel -> ?Multimedia? -> Devices tab -> Video Compression Codecs.
Is this correct under NT?
mintenwi
Posted: Dec 29 2002, 10:23 PM
In Control Panel > Sounds and Multimedia > tab Hardware > video codecs > tab Properties , I found 14 drivers all 'functioning properly':
DivX ;-) MPEG4 Video Codec (Fast Motion)
DivX ;-) MPEG4 Video Codec (Low Motion)
DivX 5.0 Pro Codec
i263832.drv
iccvid.dll
Indeo video 3.2 by Intel
Indeo video 5.11
Indeo video Raw YUV by Intel
msh261.drv
msh263.drv
msrle32.dll
msvidc32.dll
msyuv.dll
pclepim1.dll
Any suggestions about conflicts?
jcsston
Posted: Dec 29 2002, 10:49 PM
Matroska Dev
sad.gif I have all those on my system and more.
mintenwi
Posted: Dec 30 2002, 01:07 AM
Then I can assume that I have no 'wrong coders' installed. But what is the problem than?
ThX for your effort!
6 replies since Dec 29 2002, 02:59 AM Track this topic | Email this topic | Print this topic
