Export Wav From Vd Mod, with 2 Audio Tracks have the .wav
guymontag
Posted: Dec 8 2002, 06:35 PM
I've an .avi file, divx video compression and 2 Mp3 VBR audio tracks;
when I try to export to .wav in VD Mod, there's a crash!
Do you know this?
Thx
Suiryc
Posted: Dec 9 2002, 05:55 PM
Developer of VirtualdubMod
Group: VirtualdubMod Team
Hi
is there a report with the crash ?
ChristianHJW
Posted: Dec 10 2002, 09:24 AM
Makes me want to ask a question :
Is it possible to export both same time at all ? I thought its necessary to select either of them, by setting 'no audio' on either first or 2nd stream, and then use 'save WAV' to dump it ?
Also, make sure you set 'audio' to 'direct stream copy' , full processing mode when decoding to PCM WAV dont work with most MP3 ACM codecs because its Lame VBR MP3 AFAIK ...
Suiryc
Posted: Dec 10 2002, 03:07 PM
You can only extract one audio stream at a time.
The program should warn you (and won't extract anything) if the 2 audio streams are selected. Same if you deselected both streams (i.e. the program have nothing to extract ^^).
3 replies since Dec 8 2002, 06:35 PM Track this topic | Email this topic | Print this topic
