Opening Non-dvd Mpeg2 Files With Audiostream
Nobody
  Posted: Dec 5 2002, 07:44 PM
Hi !
Today i tried to open my with a DVB-Card captured Mpeg2 videos. It worked, i renamed it to *.vob and the config window showed up, but i can't use my Audiostream, it is no Ac3-Stream but normal mpeg2-Audio. I have tested to open the Video with my Media Player and with it i have Video and Audio but VirtualdubMod simply don't accepts no Audiostreams but Ac3. Is Anyone Out there with a sollution ? To watch my Movies without Audio is only half of it's fun .....
pulco-citron
Posted: Dec 11 2002, 09:27 AM
The next release will correct some problems with audio streams for non-DVD files.
Also remember that audio streams are managed via hard disk, not via "avi audio".
Nobody
Posted: Dec 11 2002, 03:14 PM
Thanx for that info, i hoped that this would be fixed. But i found out another problem : If i cut the mpeg-file i get desynchs (with wave audio, for test).
ChristianHJW
Posted: Dec 13 2002, 02:27 AM
What program do you use to edit the MPEG files ? And why is it WAV audio ( do you mean PCM uncompressed audio ? ) ? You cant use uncompressed PCM in MPEG container ...
Nobody
Posted: Dec 13 2002, 02:57 PM
I'm using Virtualdubmod, i only want to get my mpeg2-files into avi, without the use of much diskspace or time. At present i take my mpeg2 files and open them with virtualdubmod. The mpeg-audio can't be used so i have to convert it inot pcm wave and open it seperatily with virtualdubmod to put video and audio together. The problem is, that i can't take the mpeg-audio directly and that there are very much problems on cutting the file.
smokeslikeapoet
Posted: Dec 15 2002, 05:08 AM
Demux the capture with DVD2AVI, encoded the video separately from the audio and then mux them when you're finished encoding.
Nobody
  Posted: Dec 15 2002, 11:20 AM
Currently Im exaclty doing this, but i think that there must be a way to encode mpeg2-files directly with virtualdub to save time and space. I thought that the solution would be Virtualdubmod, but i cant use the audio-stream and cutting tje don't works correctly too so If there are any suggestions to encode with virtualdub without demuxing or seperate encoding please tell me laugh.gif
6 replies since Dec 5 2002, 07:44 PM Track this topic | Email this topic | Print this topic
