| affter333 |
| Posted: Dec 28 2004, 10:35 PM |
I use vdub's internal resize filter to add border (expand frame) without resizing the original image.
So I just used nearest neighbor method and choose the same dimension, while adding borders to it.
Since the video is a window screen capture , so it's very noticable that the original frame became blurry.
its not supposed to happen. because if I choose nearest neighbor method and same dimension. the image should be left unchanged, isn't it?
| Posted: Dec 28 2004, 10:47 PM |
It shouldn't, because nearest-neighbor sampling doesn't blend any pixels together. The output pane sometimes doesn't update immediately, though -- try right-clicking on the output pane and choosing "reset to exact size," then jump to a different frame. |
