V.dubmod Stops Working Somewhere In A Job, all versios after 1.5.1.1a does this...
AlCapone
Posted: Jun 24 2004, 07:44 PM
Thank you for this program.
System: Dual 2.8Ghz with 1GB ECC RAM. 3Ware SATA RAID (this is a no-biterror computer rock stable on all jobs.)
I tried virtually any version after 1.5.1.1a (1.5.1.1a still works perfectly)
all of them stop randomly somewhere in a re-encoding or muxing job, and just stop working, the program is running fine and can be stopped by clinking "abort" anytime.
while VirtualDubMod do "nothing" it logs:
[!] Dub: Processing thread has not cycled for ten seconds -- possible
livelock. (Thread location: 7FFE0304)
[!] Dub: I/O thread has not cycled for ten seconds -- possible livelock.
AlCapone
Posted: Jul 2 2004, 04:57 PM
bump'ing .... hoping for somebody to fix this bug....
stephanV
Posted: Jul 2 2004, 05:02 PM
could you perhaps be more specific on the kind of thing you are doing (which codecs you use, what you mux, which container)
also what OS you are on etc.
does it happen with normal VDub as well?
useful links:
AlCapone
Posted: Jul 3 2004, 04:14 PM
muxing freshly rendered XviD video with fresh VBR MP3 file.
(any set of video+audio)
>>which container
I do not know what this is(/where to find it)
XP , SP1 & all significant patches.
eighter vdub or nandub does it just fine.
I am still using 1.5.1.1a , it process the same files just fine, each time.
-in fact, i do not think I ever seen vDubmod do anything bad (hang/freeze/crash) apart from this "stopping" , that were implemented after 1.5.1.1a smile.gif
Morsa
Posted: Jul 3 2004, 08:19 PM
Well the same problem happens to me all the time.Vdub and Vdubmod related.
Don't know what it is.In my case I'm outputting image sequences.
stephanV
Posted: Jul 4 2004, 10:01 AM
QUOTE (AlCapone @ Jul 3 2004, 06:14 PM)
>>which container
container is the "wrapper" in which you put your media streams eg AVI, OGM and Matroska (for VDM)
useful links:
AlCapone
Posted: Jul 4 2004, 12:25 PM
ok, then the XviD is in AVI , and the VBP MP3 comes in MP3 . both sources contain only one stream until muxed into an AVI with both XviD & MP3 audio.
Jogobo
Posted: Jul 12 2004, 12:54 PM
I can confirm that this problem occurs when muxing a VBR-encoded MP3 to an AVI-file (no matter if it is the only Audio stream or a second). Converting the MP3 to CBR and everything works.
AlCapone
Posted: Jul 12 2004, 09:25 PM
I always use VBR MP3 , so it makes sense...
now ... could some kind person locate and sqash this bug ?
Jogobo
Posted: Jul 15 2004, 06:25 AM
With Build 2439 this behaviour seems to be fixed. At least with my system...
9 replies since Jun 24 2004, 07:44 PM Track this topic | Email this topic | Print this topic
