| Delvin |
Posted: May 17 2004, 04:43 AM |
i'v got next report during encoding of Zatoichi movie with GordianKnot 0.28.7.2 (default installation) and XviD 1.0 RC4 (Codename Hola!).
Zatoichi.avs: LoadPlugin("D:\PROGRA~1\GORDIA~1\mpeg2dec3.dll") LoadPlugin("D:\PROGRA~1\GORDIA~1\undot.dll") LoadPlugin("D:\PROGRA~1\GORDIA~1\decomb.dll") LoadPlugin("D:\PROGRA~1\GORDIA~1\Convolution3d.dll") mpeg2source("E:\DVD\Zatoichi\Zatoichi.d2v") crop(4,4,712,464) FieldDeinterlace() LanczosResize(704,384) Undot() Convolution3d("moviehq")
This is a first time when i see a this kind of problem with GK and vdubmod, alot of movies before were encoded without any errors...
VirtualDub crash report -- build 2389 (release) --------------------------------------
Disassembly: 77f83a60: ff894d147409 dec dword ptr [ecx+974144d] 77f83a66: 83f904 cmp ecx, 04 77f83a69: 7604 jbe 77f83a6f 77f83a6b: 836d1404 sub dword ptr [ebp+14], 04 77f83a6f: 68eefeeefe push feeefeee 77f83a74: ff7514 push dword ptr [ebp+14] 77f83a77: 8d4610 lea eax, [esi+10] 77f83a7a: 50 push eax 77f83a7b: e8a0d50200 call 77fb1020 77f83a80: 3b4514 cmp eax, [ebp+14] 77f83a83: 89450c mov [ebp+0c], eax 77f83a86: 7439 jz 77f83ac1 77f83a88: 64a118000000 mov eax, fs:[00000018] 77f83a8e: 8b4030 mov eax, [eax+30] 77f83a91: 8b400c mov eax, [eax+0c] 77f83a94: 8b400c mov eax, [eax+0c] 77f83a97: 83c02c add eax, 2c 77f83a9a: 50 push eax 77f83a9b: 686637f877 push 77f83766 77f83aa0: e88622ffff call 77f75d2b 77f83aa5: 8b450c mov eax, [ebp+0c] 77f83aa8: 8d443010 lea eax, [eax+esi+10] 77f83aac: 50 push eax 77f83aad: 56 push esi 77f83aae: 687237f877 push 77f83772 77f83ab3: e87322ffff call 77f75d2b 77f83ab8: 83c414 add esp, 14 77f83abb: 56 push esi 77f83abc: e879900100 call 77f9cb3a 77f83ac1: 0fb706 movzx eax, word ptr [esi] 77f83ac4: 294328 sub [ebx+28], eax 77f83ac7: 8a4705 mov al, [edi+05] 77f83aca: 2410 and al, 10 77f83acc: a810 test al, 10 77f83ace: 884605 mov [esi+05], al 77f83ad1: 740b jz 77f83ade 77f83ad3: 0fb64604 movzx eax, byte ptr [esi+04] 77f83ad7: 8b448358 mov eax, [ebx+eax*4+58] 77f83adb: 897038 mov [eax+38], esi 77f83ade: 57 push edi 77f83adf: 53 push ebx 77f83ae0: e894f4ffff call 77f82f79 77f83ae5: 8b4708 mov eax, [edi+08] 77f83ae8: 8b4f0c mov ecx, [edi+0c] 77f83aeb: 3bc1 cmp eax, ecx 77f83aed: 8901 mov [ecx], eax <-- FAULT 77f83aef: 894804 mov [eax+04], ecx 77f83af2: 7521 jnz 77f83b15 77f83af4: 668b07 mov ax, [edi] 77f83af7: 663d8000 cmp ax, 0080 77f83afb: 7318 jnc 77f83b15 77f83afd: 0fb7c8 movzx ecx, al 77f83b00: 8bc1 mov eax, ecx 77f83b02: 83e107 and ecx, 07 77f83b05: b201 mov dl, 01 77f83b07: c1e803 shr eax, 03 77f83b0a: d2e2 shl dl, cl 77f83b0c: 8d841858010000 lea eax, [eax+ebx+158] 77f83b13: 3010 xor [eax], dl 77f83b15: 8a4705 mov al, [edi+05] 77f83b18: a804 test al, 04 77f83b1a: 746c jz 77f83b88 77f83b1c: a802 test al, 02 77f83b1e: 0fb70f movzx ecx, word ptr [edi] 77f83b21: 8d0ccdf0ffffff lea ecx, [ecx*8+fffffff0] 77f83b28: 894d14 mov [ebp+14], ecx 77f83b2b: 7409 jz 77f83b36 77f83b2d: 83f904 cmp ecx, 04 77f83b30: 7604 jbe 77f83b36 77f83b32: 836d1404 sub dword ptr [ebp+14], 04 77f83b36: 68eefeeefe push feeefeee 77f83b3b: ff7514 push dword ptr [ebp+14] 77f83b3e: 8d4710 lea eax, [edi+10] 77f83b41: 50 push eax 77f83b42: e8d9d40200 call 77fb1020 77f83b47: 3b4514 cmp eax, [ebp+14] 77f83b4a: 89450c mov [ebp+0c], eax 77f83b4d: 7439 jz 77f83b88 77f83b4f: 64a118000000 mov eax, fs:[00000018] 77f83b55: 8b4030 mov eax, [eax+30] 77f83b58: 8b400c mov eax, [eax+0c] 77f83b5b: 8b400c mov eax, [eax+0c] 77f83b5e: 83 db 83 77f83b5f: c0 db c0
EAX = 00000000 EBX = 01290000 ECX = 00000000 EDX = 012f68c8 EBP = 0012f6cc DS:ESI = 0023:012f6000 ES:EDI = 0023:012f68c8 SS:ESP = 0023:0012f6c0 CS:EIP = 001b:77f83aed FS = 003b GS = 0000 EFLAGS = 00010246 FPUCW = ffff027f FPUTW = ffffffff
MM0 = ade0000000000000 MM1 = e358000000000000 MM2 = c900000000000000 MM3 = c900000000000000 MM4 = cd0cccccccccd000 MM5 = 8000000000000000 MM6 = 8257000000000000 MM7 = 8000000000000000
Crash context: An out-of-bounds memory access (access violation) occurred in module 'ntdll'.
Thread traces:
Thread 00000a14 (Main thread) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Init.cpp(344) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Init.cpp(387) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Init.cpp(407) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(646) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(676)
Thread call stack:77f83aed: ntdll!RtlSizeHeap [77f50000+33316+7d7] 77f58cca: ntdll!RtlFreeHeap [77f50000+8a3e+28c] 77f59037: ntdll!RtlFreeHeap [77f50000+8a3e+5f9] 01264575: mpeg2dec3!closeVideo [01240000+10920+13c55] 0124b489: mpeg2dec3!?Close@CMPEG2Decoder@@QAEXXZ [01240000+b370+119] 0124c483: mpeg2dec3!?Copyoddeven@CMPEG2Decoder@@IAEXPAUYV12PICT@@00@Z [01240000+bdc0+6c3] 0124c438: mpeg2dec3!?Copyoddeven@CMPEG2Decoder@@IAEXPAUYV12PICT@@00@Z [01240000+bdc0+678] 00e1f150: avisynth!avs_create_script_environment [00e10000+e6e0+a70] 00e1ea68: avisynth!avs_create_script_environment [00e10000+e6e0+388] 00e5ab57: avisynth!DllCanUnloadNow [00e10000+f4c0+3b697] 00e5aaf8: avisynth!DllCanUnloadNow [00e10000+f4c0+3b638] 00e1f150: avisynth!avs_create_script_environment [00e10000+e6e0+a70] 00e1ea68: avisynth!avs_create_script_environment [00e10000+e6e0+388] 012ca3eb: decomb!_AvisynthPluginInit2@4 [012c0000+17f0+8bfb] 012ca348: decomb!_AvisynthPluginInit2@4 [012c0000+17f0+8b58] 00e1f150: avisynth!avs_create_script_environment [00e10000+e6e0+a70] 00e1ea68: avisynth!avs_create_script_environment [00e10000+e6e0+388] 00e52b5c: avisynth!DllCanUnloadNow [00e10000+f4c0+3369c] 00e4d0d8: avisynth!DllCanUnloadNow [00e10000+f4c0+2dc18] 00e53322: avisynth!DllCanUnloadNow [00e10000+f4c0+33e62] 00e52dd8: avisynth!DllCanUnloadNow [00e10000+f4c0+33918] 00e1f150: avisynth!avs_create_script_environment [00e10000+e6e0+a70] 00e1ea68: avisynth!avs_create_script_environment [00e10000+e6e0+388] 012a18cc: undot!000018cc 012a1878: undot!00001878 00e1f150: avisynth!avs_create_script_environment [00e10000+e6e0+a70] 00e1ea68: avisynth!avs_create_script_environment [00e10000+e6e0+388] 00e6915c: avisynth!DllCanUnloadNow [00e10000+f4c0+49c9c] 00e690d8: avisynth!DllCanUnloadNow [00e10000+f4c0+49c18] 00e1f150: avisynth!avs_create_script_environment [00e10000+e6e0+a70] 00e1ea68: avisynth!avs_create_script_environment [00e10000+e6e0+388] 00e19e3b: avisynth!00009e3b 00e1a0e2: avisynth!0000a0e2 77c2ab33: msvcrt!free [77c10000+1aa6b+c8] 00e1a078: avisynth!0000a078 00e1faa5: avisynth!DllCanUnloadNow [00e10000+f4c0+5e5] 00e1f87a: avisynth!DllCanUnloadNow [00e10000+f4c0+3ba] 73b552d5: AVIFIL32!AVIFileRelease [73b50000+52cb+a] 004b40a1: AVIReadHandler::_destruct() 004b1daf: AVIReadHandler::~AVIReadHandler() 004b419d: AVIReadHandler::Release() 004b655f: InputFileAVI::~InputFileAVI() 004b8a78: InputFileAVI::(special)() 00449080: ?$vdrefcounted::Release() 00465f2c: ?$vdrefptr::(special)() 00464a95: CloseAVI() 0048daea: VDProject::Close() 00526e5a: CScriptInterpreter::ParseExpression2() 77f58bcd: ntdll!RtlFreeHeap [77f50000+8a3e+18f] 77f59037: ntdll!RtlFreeHeap [77f50000+8a3e+5f9] 77f83ae5: ntdll!RtlSizeHeap [77f50000+33316+7cf] 77f58cca: ntdll!RtlFreeHeap [77f50000+8a3e+28c] 77f58ebe: ntdll!RtlFreeHeap [77f50000+8a3e+480] 77f59037: ntdll!RtlFreeHeap [77f50000+8a3e+5f9] 77f5bfb4: ntdll!NtReadFile [77f50000+bfa8+c] 77e7abbd: kernel32!ReadFile [77e60000+1ab4e+6f] 0052765e: CScriptInterpreter::LookupRootVariable() 00527c20: CScriptInterpreter::Token() 00526a48: CScriptInterpreter::ParseExpression() 00527a88: CScriptInterpreter::Token() 00526808: CScriptInterpreter::ExecuteLine() 0056942b: fgetc() 004827ee: ?$vector::push_back() 00496d65: RunScript() 0047dfed: ParseCommandLine() 77dd1859: ADVAPI32!RegCloseKey [77dd0000+17d8+81] 004883d2: QueryConfigDword() 004630f5: DetectDivX() 0047d376: Init() 00482e10: WinMain@16() 77f59bf9: ntdll!RtlReleasePebLock [77f50000+9bea+f] 77e61a57: kernel32!GetStartupInfoA [77e60000+177e+2d9] 77e619ef: kernel32!GetStartupInfoA [77e60000+177e+271] 00567414: atexit() 0056907e: WinMainCRTStartup() 77e814c7: kernel32!GetCurrentDirectoryW [77e60000+21483+44]
-- End of report |
| Delvin |
Posted: May 18 2004, 04:16 PM |
Problem was solved with success only when i used standard VirtualDub (lastest build available from sourceforge) instead of VDubMod, with *Full Processing* (not tested with *Fast Recompress*), for 2nd pass (1st pass was ok with vdubmod). I think, this means, that a source of problem is in depths of vdubmod's sourcecode |
| jusix |
| Posted: May 22 2004, 09:14 AM |
I have probably the same problem. DVD2AVI (vob to avs) -> Avisynth (avs script) -> VirtualDubMod -> Xvid
DVD2AVIdg 1.2.0 RC7 MPEG2Dec3dg.dll (version: 1.0.1.0 MPEG2DEC3 for Avisynth 2.5, size 254'033 bytes) VirtualDubMod 1.5.10 build 2439 Xvid 1.0 RC4 (koepi's build 9.5.2004)
Avisynth script: LoadPlugin("MPEG2Dec3dg.dll") MPEG2Source("krt.d2v")
File krt.d2v contains more parts, which must be encoded to separated AVI files. I created jobs in Job control. Immediately after first pass finished, VirtualDubMod crashes. Maybe there is problem of closing AVS file. Mentioned here in forum.
Crashlog: VirtualDub crash report -- build 2439 (release) --------------------------------------
Disassembly: 77f73960: 45 inc ebp 77f73961: 0c89 or al, 89 77f73963: 45 inc ebp 77f73964: 08743964 or [ecx+edi+64], dh 77f73968: a118000000 mov eax, [00000018] 77f7396d: 8b4030 mov eax, [eax+30] 77f73970: 8b400c mov eax, [eax+0c] 77f73973: 8b400c mov eax, [eax+0c] 77f73976: 83c02c add eax, 2c 77f73979: 50 push eax 77f7397a: 681a37f777 push 77f7371a 77f7397f: e8a723ffff call 77f65d2b 77f73984: 8b4508 mov eax, [ebp+08] 77f73987: 8d443810 lea eax, [eax+edi+10] 77f7398b: 50 push eax 77f7398c: 57 push edi 77f7398d: 682637f777 push 77f73726 77f73992: e89423ffff call 77f65d2b 77f73997: 83c414 add esp, 14 77f7399a: 57 push edi 77f7399b: e89a910100 call 77f8cb3a 77f739a0: 8a4605 mov al, [esi+05] 77f739a3: 2410 and al, 10 77f739a5: a810 test al, 10 77f739a7: 884705 mov [edi+05], al 77f739aa: 740b jz 77f739b7 77f739ac: 0fb64704 movzx eax, byte ptr [edi+04] 77f739b0: 8b448358 mov eax, [ebx+eax*4+58] 77f739b4: 897838 mov [eax+38], edi 77f739b7: 0fb70f movzx ecx, word ptr [edi] 77f739ba: 8b4510 mov eax, [ebp+10] 77f739bd: 0108 add [eax], ecx 77f739bf: 0fb70f movzx ecx, word ptr [edi] 77f739c2: 294b28 sub [ebx+28], ecx 77f739c5: f6470510 test [edi+05], 10 77f739c9: 668b00 mov ax, [eax] 77f739cc: 8bf7 mov esi, edi 77f739ce: 668907 mov [edi], ax 77f739d1: 750d jnz 77f739e0 77f739d3: 8b4510 mov eax, [ebp+10] 77f739d6: 8b08 mov ecx, [eax] 77f739d8: 668bc1 mov ax, cx 77f739db: 668944cf02 mov [edi+ecx*8+02], ax 77f739e0: f6460510 test [esi+05], 10 77f739e4: 0f85c2010000 jnz 77f73bac 77f739ea: 8b4510 mov eax, [ebp+10] 77f739ed: 8b00 mov eax, [eax] 77f739ef: 8d3cc6 lea edi, [esi+eax*8] 77f739f2: f6470501 test [edi+05], 01 <-- FAULT 77f739f6: 0f85b0010000 jnz 77f73bac 77f739fc: 0fb70f movzx ecx, word ptr [edi] 77f739ff: 03c8 add ecx, eax 77f73a01: 81f900fe0000 cmp ecx, 0000fe00 77f73a07: 0f879f010000 ja 77f73bac 77f73a0d: 807d1400 cmp byte ptr [ebp+14], 00 77f73a11: 0f84b0000000 jz 77f73ac7 77f73a17: 56 push esi 77f73a18: 53 push ebx 77f73a19: e85bf5ffff call 77f72f79 77f73a1e: 8b4608 mov eax, [esi+08] 77f73a21: 8b4e0c mov ecx, [esi+0c] 77f73a24: 3bc1 cmp eax, ecx 77f73a26: 8901 mov [ecx], eax 77f73a28: 894804 mov [eax+04], ecx 77f73a2b: 7521 jnz 77f73a4e 77f73a2d: 668b06 mov ax, [esi] 77f73a30: 663d8000 cmp ax, 0080 77f73a34: 7318 jnc 77f73a4e 77f73a36: 0fb7c8 movzx ecx, al 77f73a39: 8bc1 mov eax, ecx 77f73a3b: 83e107 and ecx, 07 77f73a3e: b201 mov dl, 01 77f73a40: c1e803 shr eax, 03 77f73a43: d2e2 shl dl, cl 77f73a45: 8d841858010000 lea eax, [eax+ebx+158] 77f73a4c: 3010 xor [eax], dl 77f73a4e: 8a4605 mov al, [esi+05] 77f73a51: a804 test al, 04 77f73a53: 746c jz 77f73ac1 77f73a55: a802 test al, 02 77f73a57: 0fb70e movzx ecx, word ptr [esi] 77f73a5a: 8d0ccd lea ecx, [ebp+ecx*8] 77f73a5d: f0 lock 77f73a5e: ff db ff 77f73a5f: ff db ff
EAX = 0000fffb EBX = 01380000 ECX = 0012f570 EDX = 01380001 EBP = 0012f4d0 DS:ESI = 0023:01384750 ES:EDI = 0023:01404728 SS:ESP = 0023:0012f4c4 CS:EIP = 001b:77f739f2 FS = 003b GS = 0000 EFLAGS = 00010246 FPUCW = ffff027f FPUTW = ffffffff
MM0 = 0001000000000000 MM1 = 0000000000000000 MM2 = 0000000000000000 MM3 = 0000000000000000 MM4 = 0000000000000000 MM5 = 0000000000000000 MM6 = 0000000000000000 MM7 = 0000000000000000
Thread traces:
Thread 00000ee4 (Main thread) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(555) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(555) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(569) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1819) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1837) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(124) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(126) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(124) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(126) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(409) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(409) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(429) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(517) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(530) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(517) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(530)
Thread call stack:77f739f2: ntdll!RtlSizeHeap [77f40000+33316+6dc] 77f48cca: ntdll!RtlFreeHeap [77f40000+8a3e+28c] 77f844cb: ntdll!RtlRemoteCall [77f40000+442ea+1e1] 77f48bcd: ntdll!RtlFreeHeap [77f40000+8a3e+18f] 77f49037: ntdll!RtlFreeHeap [77f40000+8a3e+5f9] 77f49037: ntdll!RtlFreeHeap [77f40000+8a3e+5f9] 013545f5: MPEG2Dec3dg!closeVideo [01330000+10970+13c85] 0133b0d8: MPEG2Dec3dg!?Close@CMPEG2Decoder@@QAEXXZ [01330000+afb0+128] 0133c073: MPEG2Dec3dg!?Copyoddeven@CMPEG2Decoder@@IAEXPAUYV12PICT@@00@Z [01330000+ba00+673] 0133c028: MPEG2Dec3dg!?Copyoddeven@CMPEG2Decoder@@IAEXPAUYV12PICT@@00@Z [01330000+ba00+628] 00f71d19: avisynth!avs_create_script_environment [00f60000+10ae0+1239] 00f70e38: avisynth!avs_create_script_environment [00f60000+10ae0+358] 00f725f1: avisynth!DllCanUnloadNow [00f60000+12020+5d1] 00f723da: avisynth!DllCanUnloadNow [00f60000+12020+3ba] 73aa52d5: AVIFIL32!AVIFileRelease [73aa0000+52cb+a] 004b4461: AVIReadHandler::_destruct() 004b216f: AVIReadHandler::~AVIReadHandler() 004b455d: AVIReadHandler::Release() 004b68ff: InputFileAVI::~InputFileAVI() 004b8df8: InputFileAVI::(special)() 00449830: ?$vdrefcounted::Release() 004666ac: ?$vdrefptr::(special)() 00465215: CloseAVI() 0048e10a: VDProject::Close() 0052757a: CScriptInterpreter::ParseExpression2() 77f844a8: ntdll!RtlRemoteCall [77f40000+442ea+1be] 77f47d70: ntdll!RtlAllocateHeap [77f40000+7bae+1c2] 77f48a3a: ntdll!RtlAllocateHeap [77f40000+7bae+e8c] 0047fe1b: VDJob::Flush() 77d140c6: USER32!GetWindowLongW [77d10000+4092+34] 5b093d23: uxtheme!GetThemeColor [5b090000+3ab8+26b] 77f73ae5: ntdll!RtlSizeHeap [77f40000+33316+7cf] 77f844cb: ntdll!RtlRemoteCall [77f40000+442ea+1e1] 77f48bcd: ntdll!RtlFreeHeap [77f40000+8a3e+18f] 77f49037: ntdll!RtlFreeHeap [77f40000+8a3e+5f9] 00527d7e: CScriptInterpreter::LookupRootVariable() 00528340: CScriptInterpreter::Token() 00527168: CScriptInterpreter::ParseExpression() 005281a8: CScriptInterpreter::Token() 00526f28: CScriptInterpreter::ExecuteLine() 004627e6: ?$vector::resize() 00497379: RunScriptMemory() 0047f0ba: VDJob::Run() 0047febd: VDJob::RunAll() 00482593: JobCtlDlgProc() 77d35eb0: USER32!LockSetForegroundWindow [77d10000+25bbb+2f5] 77d13a50: USER32!00003a50 77d1c675: USER32!CharLowerBuffA [77d10000+c271+404] 77d1c4e4: USER32!CharLowerBuffA [77d10000+c271+273] 77d13a50: USER32!00003a50 77d1c6d1: USER32!DefDlgProcA [77d10000+c6b0+21] 77d13a50: USER32!00003a50 77d13b1f: USER32!00003b1f 77d15453: USER32!ReleaseDC [77d10000+5329+12a] 77d154b4: USER32!SendMessageW [77d10000+546d+47] 77d38d69: USER32!SetWindowsHookA [77d10000+288ff+46a] 77d38e48: USER32!SetWindowsHookA [77d10000+288ff+549] 77d38d2a: USER32!SetWindowsHookA [77d10000+288ff+42b] 7469a743: MSCTF!TF_DllDetachInOther [74690000+a629+11a] 7469ba32: MSCTF!TF_DllDetachInOther [74690000+a629+1409] 77d17e58: USER32!CallNextHookEx [77d10000+7e1f+39] 77d3511b: USER32!EnumClipboardFormats [77d10000+247c5+956] 77d13a50: USER32!00003a50 77d13b1f: USER32!00003b1f 77d13d79: USER32!GetMessageW [77d10000+3c54+125] 77d3669d: USER32!GetPropA [77d10000+26650+4d] 77d13ddf: USER32!DispatchMessageW [77d10000+3dd4+b] 77d1b1f5: USER32!IsDialogMessageW [77d10000+b11c+d9] 77d35906: USER32!IsDialogMessage [77d10000+258be+48] 0047c9a8: guiCheckDialogs() 004836db: WinMain@16() 70a9f1ab: SHLWAPI!PathFindOnPathA [70a70000+29f50+525b] 70a9f1ab: SHLWAPI!PathFindOnPathA [70a70000+29f50+525b] 00565f14: atexit() 00567b5e: WinMainCRTStartup() 70a9f1ab: SHLWAPI!PathFindOnPathA [70a70000+29f50+525b] 77e614c7: kernel32!GetCurrentDirectoryW [77e40000+21483+44] 70a9f1ab: SHLWAPI!PathFindOnPathA [70a70000+29f50+525b]
-- End of report
---------------------------------------------------------------------------- Added: I'm just trying to work on it to find the problem. I tested VirtualDub and the same crash emerged! Here is part of crashlog: -------------------------------------- VirtualDub crash report -- build 18160 (release) -------------------------------------- Crash reason: Access Violation
I decided to try older Xvid Codec (XviD-1.0-RC3-29022004.exe) One time it goes well, so I prepared new project and ran it. But it crashed again.
Actually I installed DVD2AVIdg 1.3.0 + MPEG2Dec3dg.dll 1.3.0, but it crashed again. So I don't know. Maybe I have wrong DVD source which causes whese crashes.
| jusix |
| Posted: May 24 2004, 09:46 AM |
I partially solved this situation using another frameserver. In place of using AviSynth I used VFAPI. It works well. I think there is probably problem in VirtualdubMod (maybe also in VirtualDub) with closing AVS script files. I got one crash also when I close opened AVS script (using File/Close video file) |
