VirtualDubMod Crash Report -- Build 2389 (release), 77f41ce1: f6470501 test [edi+05], 01 <--
bYACO
Posted: Jan 13 2004, 09:39 PM
First sorry for my poor english i hope you understand me
I have a problem with a VirtualDubMod 1.5.10.1 that i use from Gordian Knot. Each time i try to encode with divx 5.11
the program reports an error and it closes.
I dont know if the problem is a hardware or software bug.
Im afraid of the crash is a CPU or memory problem.
Please Could you help me¿?¿ It is very important for me
Thanks
VirtualDub crash report -- build 2389 (release)
Disassembly:
77f41c60: e8433e0200 call 77f65aa8
77f41c65: 85c0 test eax, eax
77f41c67: 75d9 jnz 77f41c42
77f41c69: 57 push edi
77f41c6a: e86f390200 call 77f655de
77f41c6f: f6460c40 test [esi+0c], 40
77f41c73: 7412 jz 77f41c87
77f41c75: 895df4 mov [ebp-0c], ebx
77f41c78: c745f800000080 mov dword ptr [ebp-08], 80000000
77f41c7f: 57 push edi
77f41c80: e80b3a0200 call 77f65690
77f41c85: ebbb jmp 77f41c42
77f41c87: a15c32fb77 mov eax, [77fb325c]
77f41c8c: 83f801 cmp eax, 01
77f41c8f: 0f87a51f0200 ja 77f63c3a
77f41c95: 391d6032fb77 cmp [77fb3260], ebx
77f41c9b: 75e2 jnz 77f41c7f
77f41c9d: 391d5832fb77 cmp [77fb3258], ebx
77f41ca3: 75da jnz 77f41c7f
77f41ca5: e93d5c0300 jmp 77f778e7
77f41caa: 55 push ebp
77f41cab: 8bec mov ebp, esp
77f41cad: 53 push ebx
77f41cae: 8b5d08 mov ebx, [ebp+08]
77f41cb1: 56 push esi
77f41cb2: 8b750c mov esi, [ebp+0c]
77f41cb5: 0fb74602 movzx eax, word ptr [esi+02]
77f41cb9: 57 push edi
77f41cba: c1e003 shl eax, 03
77f41cbd: 8bfe mov edi, esi
77f41cbf: 2bf8 sub edi, eax
77f41cc1: 3bfe cmp edi, esi
77f41cc3: 740a jz 77f41ccf
77f41cc5: f6470501 test [edi+05], 01
77f41cc9: 0f840e040000 jz 77f420dd
77f41ccf: f6460510 test [esi+05], 10
77f41cd3: 0f8584000000 jnz 77f41d5d
77f41cd9: 8b4510 mov eax, [ebp+10]
77f41cdc: 8b00 mov eax, [eax]
77f41cde: 8d3cc6 lea edi, [esi+eax*8]
77f41ce1: f6470501 test [edi+05], 01 <-- FAULT
77f41ce5: 7576 jnz 77f41d5d
77f41ce7: 0fb70f movzx ecx, word ptr [edi]
77f41cea: 03c8 add ecx, eax
77f41cec: 81f900fe0000 cmp ecx, 0000fe00
77f41cf2: 7769 ja 77f41d5d
77f41cf4: 807d1400 cmp byte ptr [ebp+14], 00
77f41cf8: 0f85651d0300 jnz 77f73a63
77f41cfe: 8a4705 mov al, [edi+05]
77f41d01: 2410 and al, 10
77f41d03: a810 test al, 10
77f41d05: 884605 mov [esi+05], al
77f41d08: 740b jz 77f41d15
77f41d0a: 0fb64604 movzx eax, byte ptr [esi+04]
77f41d0e: 8b448358 mov eax, [ebx+eax*4+58]
77f41d12: 897038 mov [eax+38], esi
77f41d15: 57 push edi
77f41d16: 53 push ebx
77f41d17: e8f0faffff call 77f4180c
77f41d1c: 8b4708 mov eax, [edi+08]
77f41d1f: 8b4f0c mov ecx, [edi+0c]
77f41d22: 3bc1 cmp eax, ecx
77f41d24: 8901 mov [ecx], eax
77f41d26: 894804 mov [eax+04], ecx
77f41d29: 750d jnz 77f41d38
77f41d2b: 668b07 mov ax, [edi]
77f41d2e: 663d8000 cmp ax, 0080
77f41d32: 0f8266020000 jc 77f41f9e
77f41d38: 8a4705 mov al, [edi+05]
77f41d3b: a804 test al, 04
77f41d3d: 0f85d51d0300 jnz 77f73b18
77f41d43: 0fb70f movzx ecx, word ptr [edi]
77f41d46: 8b4510 mov eax, [ebp+10]
77f41d49: 0108 add [eax], ecx
77f41d4b: 0fb70f movzx ecx, word ptr [edi]
77f41d4e: 294b28 sub [ebx+28], ecx
77f41d51: f6460510 test [esi+05], 10
77f41d55: 668b08 mov cx, [eax]
77f41d58: 66890e mov [esi], cx
77f41d5b: 7409 jz 77f41d66
77f41d5d: 5f pop edi
77f41d5e: 8bc6 mov eax, esi
EAX = 0000fffc
EBX = 01400000
ECX = 0012f874
EDX = 01400001
EBP = 0012f7d4
DS:ESI = 0023:01be6a00
ES:EDI = 0023:01c669e0
SS:ESP = 0023:0012f7c8
CS:EIP = 001b:77f41ce1
FS = 003b
GS = 0000
EFLAGS = 00010246
FPUCW = ffff027f
FPUTW = ffffffff
MM0 = 0000000000000000
MM1 = 0000000000000000
MM2 = 0000000000000000
MM3 = 0000000000000000
MM4 = 0000000000000000
MM5 = 0000000000000000
MM6 = 0000000000000000
MM7 = 0000000000000000
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'ntdll'.
Thread traces:
Thread 00000794 (Main thread)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Init.cpp(344)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Init.cpp(387)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Init.cpp(407)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(646)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(676)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1819)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1837)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(429)
C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(569)
Thread call stack:77f41ce1: ntdll!RtlpUnWaitCriticalSection [77f40000+1bfe+e3]
77f41dc9: ntdll!RtlpUnWaitCriticalSection [77f40000+1bfe+1cb]
77f4166a: ntdll!RtlFreeHeap [77f40000+156b+ff]
013d4575: mpeg2dec3!closeVideo [013b0000+10920+13c55]
013bb489: mpeg2dec3!?Close@CMPEG2Decoder@@QAEXXZ [013b0000+b370+119]
013bc483: mpeg2dec3!?Copyoddeven@CMPEG2Decoder@@IAEXPAUYV12PICT@@00@Z [013b0000+bdc0+6c3]
013bc438: mpeg2dec3!?Copyoddeven@CMPEG2Decoder@@IAEXPAUYV12PICT@@00@Z [013b0000+bdc0+678]
00f8f150: avisynth!avs_create_script_environment [00f80000+e6e0+a70]
00f8ea68: avisynth!avs_create_script_environment [00f80000+e6e0+388]
00fcab57: avisynth!DllCanUnloadNow [00f80000+f4c0+3b697]
00fcaaf8: avisynth!DllCanUnloadNow [00f80000+f4c0+3b638]
00fc2b5c: avisynth!DllCanUnloadNow [00f80000+f4c0+3369c]
00fbd0d8: avisynth!DllCanUnloadNow [00f80000+f4c0+2dc18]
00fc3322: avisynth!DllCanUnloadNow [00f80000+f4c0+33e62]
00fc2dd8: avisynth!DllCanUnloadNow [00f80000+f4c0+33918]
00f89e3b: avisynth!00009e3b
00f8a0e2: avisynth!0000a0e2
77bfab33: msvcrt!free [77be0000+1aa6b+c8]
00f8a078: avisynth!0000a078
00f8faa5: avisynth!DllCanUnloadNow [00f80000+f4c0+5e5]
00f8f87a: avisynth!DllCanUnloadNow [00f80000+f4c0+3ba]
73ad52d5: AVIFIL32!AVIFileRelease [73ad0000+52cb+a]
004b40a1: AVIReadHandler::_destruct()
004b1daf: AVIReadHandler::~AVIReadHandler()
004b419d: AVIReadHandler::Release()
004b655f: InputFileAVI::~InputFileAVI()
004b8a78: InputFileAVI::(special)()
00449080: ?$vdrefcounted::Release()
00465f2c: ?$vdrefptr::(special)()
00464a95: CloseAVI()
0048daea: VDProject::Close()
00526e5a: CScriptInterpreter::ParseExpression2()
77f4164e: ntdll!RtlFreeHeap [77f40000+156b+e3]
77e62441: kernel32!OpenMutexA [77e40000+22391+b0]
77f439ba: ntdll!RtlDetermineDosPathNameType_U [77f40000+36b0+30a]
77f43a17: ntdll!RtlDosPathNameToNtPathName_U [77f40000+39d0+47]
77f41690: ntdll!RtlFreeHeap [77f40000+156b+125]
0052765e: CScriptInterpreter::LookupRootVariable()
00527c20: CScriptInterpreter::Token()
00526a48: CScriptInterpreter::ParseExpression()
00527a88: CScriptInterpreter::Token()
00526808: CScriptInterpreter::ExecuteLine()
0056942b: fgetc()
004827ee: ?$vector::push_back()
00496d65: RunScript()
0047dfed: ParseCommandLine()
77da1859: ADVAPI32!RegCloseKey [77da0000+17d8+81]
004883d2: QueryConfigDword()
004630f5: DetectDivX()
0047d376: Init()
00482e10: WinMain@16()
77f4202c: ntdll!RtlReleasePebLock [77f40000+201d+f]
77e41a57: kernel32!GetStartupInfoA [77e40000+177e+2d9]
77e419ef: kernel32!GetStartupInfoA [77e40000+177e+271]
00567414: atexit()
0056907e: WinMainCRTStartup()
77e614c7: kernel32!GetCurrentDirectoryW [77e40000+21483+44]
-- End of report
bYACO
Posted: Jan 14 2004, 08:41 AM
codec: divx 5.11
profile: Home Theather
quality: slowest
resize: lanzos
framekey:300
psicovisual: slow
size: 700mb 2 CD
audio: 2 chanels mp3 aberage bitrate 98kps 48000kpbs
before this movie i only encode two movies in one CD and resize bilinear and i dont have any problem.
bYACO
Posted: Jan 14 2004, 03:12 PM
Thanks
Disassembly:
EAX = 0000fffc
EBX = 01400000
ECX = 0012f874
EDX = 01400001
EBP = 0012f7d4
FS = 003b
GS = 0000
EFLAGS = 00010246
FPUCW = ffff027f
FPUTW = ffffffff
Crash context:
Thread traces:
0056942b: fgetc()
0047d376: Init()
00567414: atexit()
-- End of report
Posted: Jan 14 2004, 04:01 PM
I merged your two topics into one topic, in the proper forum.
Sorry, I don't know why it crashes.
3 replies since Jan 13 2004, 09:39 PM Track this topic | Email this topic | Print this topic
