Output Playback, Error generated
Sunnyorlando
  Posted: Jan 4 2004, 04:46 PM
When I try to play a video, not having modifed it at all, if I press on the "Output Playback" button I get this error: "audio filter graph lacks an ouput node".
The only thing I have changed is in the "Audio Menu", I have selected "Full Processing Mode". If I don't select that, then it plays the same as pressing "Input Playback". I am new at this program and I am trying to familiarize myself with the functions. Can someone explain the difference between these two and why I may be getting this error?
Also, I have not been able to have my favorite .vdf filters stay loaded by placing them in the "plugins/" folder as explained in the VirtualDub filters page. Can the internal filters also be kept loaded (load automatically) upon starting VirtualDub?
Thank you!
Jaime
Kippesoep
Posted: Jan 7 2004, 06:58 PM
Are you sure you haven't also enabled "Use advanced filtering"? Because if you have, the error message is to be expected. When advanced filtering is enabled, you should also set up a filter graph using the "Filters" option. (The simplest possible filter graph can be created by adding the "input' node and then the "output" node -- this is a graph which simply copies the audio verbatim and basically does nothing).
1 replies since Jan 4 2004, 04:46 PM Track this topic | Email this topic | Print this topic
