| MaSTer-Tobias |
Posted: Dec 17 2003, 02:31 PM |
Hi @ all,
i got a problem when i decoded a vob (ac3sound) with the newest vdubmod version after half of the encoding time an error occured:
|----------------------------------------------------------------------------| | VirtualDub Error | |----------------------------------------------------------------------------| | (X) video compression error: An unknown error occured (may be corrupt data). (error code-100)| | | OK | | |----------------------------------------------------------------------------|
i hope you got the answer for this error? because i don't know what i did wrong!
further informations: i got a p4 2,41ghz 1024mb ram all codecs installed newest virtual dubmod version error occured while encoding (~58% encoded) video compression used: divX 5.1.1 audio compression used: newest ac3 codec used filters in vdm: logo 1.4 (donald craft); resize virtualdubmod newest version my plan: dvdecryptor + dvd2avi + vfapi --> vob files + ac3 --> AVI --------------------------------------------------- thx for reply
the crashinfo.txt:
VirtualDub crash report -- build 2389 (release) --------------------------------------
Disassembly: 0046f540: 98 cwde 0046f541: 0200 add al, [eax] 0046f543: 00578b add [edi-75], dl 0046f546: 780c js Dubber::Abort+19 (0046f554) 0046f548: c6869b00000001 mov byte ptr [esi+9b], 01 0046f54f: c6869a00000001 mov byte ptr [esi+9a], 01 0046f556: eb24 jmp Dubber::Abort+41 (0046f57c) 0046f558: 8d8f8c010000 lea ecx, [edi+18c] 0046f55e: e8b28e0b00 call VDSignalBase::signal (00528415) 0046f563: 8d8f90010000 lea ecx, [edi+190] 0046f569: e8a78e0b00 call VDSignalBase::signal (00528415) 0046f56e: 8d8f98010000 lea ecx, [edi+198] 0046f574: e8234affff call AVIPipe::abort (00463f9c) 0046f579: 8b7f0c mov edi, [edi+0c] 0046f57c: 85ff test edi, edi 0046f57e: 75d8 jnz Dubber::Abort+1d (0046f558) 0046f580: 8b8ec4000000 mov ecx, [esi+c4] 0046f586: e8114affff call AVIPipe::abort (00463f9c) 0046f58b: 57 push edi 0046f58c: 57 push edi 0046f58d: 6800040000 push 00000400 0046f592: ff35d8ed5e00 push dword ptr [005eedd8] 0046f598: ff1550855800 call dword ptr [00588550] 0046f59e: 5f pop edi 0046f59f: 5e pop esi 0046f5a0: c3 ret 0046f5a1: 33c0 xor eax, eax 0046f5a3: 38819a000000 cmp [ecx+9a], al 0046f5a9: 0f94c0 setz al 0046f5ac: c3 ret 0046f5ad: 8a819b000000 mov al, [ecx+9b] 0046f5b3: c3 ret 0046f5b4: 8a8199000000 mov al, [ecx+99] 0046f5ba: c3 ret 0046f5bb: c3 ret 0046f5bc: 8b442404 mov eax, [esp+04] 0046f5c0: 53 push ebx 0046f5c1: 8b1db4835800 mov ebx, [005883b4] 0046f5c7: 56 push esi 0046f5c8: 8bf0 mov esi, eax 0046f5ca: 57 push edi 0046f5cb: 8bf9 mov edi, ecx 0046f5cd: 8b87b8000000 mov eax, [edi+b8] 0046f5d3: c1e603 shl esi, 03 0046f5d6: ffb640415900 push dword ptr [esi+594140] 0046f5dc: ff7008 push dword ptr [eax+08] <-- FAULT 0046f5df: ffd3 call ebx 0046f5e1: ffb644415900 push dword ptr [esi+594144] 0046f5e7: ff770c push dword ptr [edi+0c] 0046f5ea: ffd3 call ebx 0046f5ec: 5f pop edi 0046f5ed: 5e pop esi 0046f5ee: 5b pop ebx 0046f5ef: c20400 ret 0004 0046f5f2: 55 push ebp 0046f5f3: 8bec mov ebp, esp 0046f5f5: 51 push ecx 0046f5f6: 51 push ecx 0046f5f7: 56 push esi 0046f5f8: 8bf1 mov esi, ecx 0046f5fa: c7860001000001 mov dword ptr [esi+100], 00000001 000000 0046f604: 837e2000 cmp dword ptr [esi+20], 00 0046f608: 57 push edi 0046f609: 0f85f2000000 jnz Dubber::UpdateFrames+10f (0046f701) 0046f60f: e81aeb0b00 call VDGetCurrentTick (0052e12e) 0046f614: 8b8e1c020000 mov ecx, [esi+21c] 0046f61a: 8bf8 mov edi, eax 0046f61c: 8b86bc000000 mov eax, [esi+bc] 0046f622: 3bc8 cmp ecx, eax 0046f624: 8b9608020000 mov edx, [esi+208] 0046f62a: 8955f8 mov [ebp-08], edx 0046f62d: 740e jz Dubber::UpdateFrames+4b (0046f63d) 0046f62f: 89861c020000 mov [esi+21c], eax 0046f635: 89be20020000 mov [esi+220], edi 0046f63b: eb50 jmp Dubber::UpdateFrames+9b (0046f68d) 0046f63d: 85c9 test ecx, ecx 0046f63f: 74 db 74
EAX = 00000000 EBX = 77e5265d ECX = 01da05e8 EDX = 005941e0 EBP = 0012e064 DS:ESI = 0023:00000000 ES:EDI = 0023:01da05e8 SS:ESP = 0023:0012dfe0 CS:EIP = 001b:0046f5dc FS = 003b GS = 0000 EFLAGS = 00010246 FPUCW = ffff027f FPUTW = ffffffff
MM0 = 00000004bf9e6d1b MM1 = 000001d80000023e MM2 = 7ffde274f7a0dae0 MM3 = 00000206f7a0dab8 MM4 = 0000011000001e30 MM5 = 8000000000000000 MM6 = d000000000000000 MM7 = 8000000000000000
Crash context: An out-of-bounds memory access (access violation) occurred in module 'VirtualDubMod'.
Thread traces:
Thread 00000b2c (Main thread) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(555) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(569) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(124) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(126) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(124) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(126) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(124) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(126) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(124) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(126) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(409) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(409) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(429) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(555) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(555) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(569)
Thread call stack:0046f5dc: Dubber::SetPriority() 00474f19: DubStatus::StatusDlgProc() 00474d2a: DubStatus::StatusDlgProc() 00474d2a: DubStatus::StatusDlgProc() 77d13a68: USER32!00003a68 77d1c689: USER32!CharLowerBuffA [77d10000+c285+404] 77d1c4f8: USER32!CharLowerBuffA [77d10000+c285+273] 77d1c6e5: USER32!DefDlgProcA [77d10000+c6c4+21] 77d13a68: USER32!00003a68 77d13b37: USER32!00003b37 77d1546b: USER32!ReleaseDC [77d10000+5341+12a] 77d2ae64: USER32!ChildWindowFromPointEx [77d10000+1aaf1+373] 77d34f35: USER32!SetWindowsHookA [77d10000+23d57+11de] 77d2eae2: USER32!LockWindowUpdate [77d10000+1b697+344b] 77d31f2d: USER32!PostThreadMessageA [77d10000+21ead+80] 77d13a68: USER32!00003a68 77d2a4f0: USER32!TranslateMDISysAccel [77d10000+19eb7+639] 77d13a68: USER32!00003a68 77d13b37: USER32!00003b37 77d1546b: USER32!ReleaseDC [77d10000+5341+12a] 77d154cc: USER32!SendMessageW [77d10000+5485+47] 77d2e7f9: USER32!LockWindowUpdate [77d10000+1b697+3162] 77d3d487: USER32!SwapMouseButton [77d10000+2ce7b+60c] 77d3d5a4: USER32!SwapMouseButton [77d10000+2ce7b+729] 77d35305: USER32!SetWindowsHookA [77d10000+23d57+15ae] 77d1c6a5: USER32!CharLowerBuffA [77d10000+c285+420] 77d1c4f8: USER32!CharLowerBuffA [77d10000+c285+273] 77d1c509: USER32!CharLowerBuffA [77d10000+c285+284] 77d31f2d: USER32!PostThreadMessageA [77d10000+21ead+80] 77d13a68: USER32!00003a68 77d13b37: USER32!00003b37 77d13d91: USER32!GetMessageW [77d10000+3c6c+125] 77d13a4b: USER32!00003a4b 77d13df7: USER32!DispatchMessageW [77d10000+3dec+b] 77d1b41d: USER32!CallMsgFilterW [77d10000+b213+20a] 77d1d9aa: USER32!DrawStateW [77d10000+c9ba+ff0] 77d362f4: USER32!SoftModalMessageBox [77d10000+25d90+564] 77f46d94: ntdll!RtlTimeFieldsToTime [77f40000+64ff+895] 77f417e6: ntdll!RtlAllocateHeap [77f40000+16a1+145] 77f417e6: ntdll!RtlAllocateHeap [77f40000+16a1+145] 77f417e6: ntdll!RtlAllocateHeap [77f40000+16a1+145] 77f4248c: ntdll!_strcmpi [77f40000+20c0+3cc] 77f417e6: ntdll!RtlAllocateHeap [77f40000+16a1+145] 77f41778: ntdll!RtlAllocateHeap [77f40000+16a1+d7] 77f417b2: ntdll!RtlAllocateHeap [77f40000+16a1+111] 77f46d94: ntdll!RtlTimeFieldsToTime [77f40000+64ff+895] 77f46d94: ntdll!RtlTimeFieldsToTime [77f40000+64ff+895] 77f46d94: ntdll!RtlTimeFieldsToTime [77f40000+64ff+895] 77f69ba4: ntdll!RtlConvertUlongToLargeInteger [77f40000+29b3d+67] 77f417e6: ntdll!RtlAllocateHeap [77f40000+16a1+145] 77f417e6: ntdll!RtlAllocateHeap [77f40000+16a1+145] 77f41778: ntdll!RtlAllocateHeap [77f40000+16a1+d7] 77f417b2: ntdll!RtlAllocateHeap [77f40000+16a1+111] 77f4166a: ntdll!RtlFreeHeap [77f40000+156b+ff] 77f41690: ntdll!RtlFreeHeap [77f40000+156b+125] 77f4164e: ntdll!RtlFreeHeap [77f40000+156b+e3] 77d35d77: USER32!GetKeyboardLayoutNameA [77d10000+255f2+785] 77f4166a: ntdll!RtlFreeHeap [77f40000+156b+ff] 005666a8: free() 005664a8: _nh_malloc() 00559e89: (special)() 0045ff9d: ?$vector::~?$vector() 0052a7bb: VDaswprintf() 77f46eaf: ntdll!RtlTimeFieldsToTime [77f40000+64ff+9b0] 77f65c1a: ntdll!NtFreeVirtualMemory [77f40000+25c0e+c] 77f46a00: ntdll!RtlTimeFieldsToTime [77f40000+64ff+501] 77f65c1a: ntdll!NtFreeVirtualMemory [77f40000+25c0e+c] 77f46a00: ntdll!RtlTimeFieldsToTime [77f40000+64ff+501] 77f41690: ntdll!RtlFreeHeap [77f40000+156b+125] 77f4164e: ntdll!RtlFreeHeap [77f40000+156b+e3] 77f4166a: ntdll!RtlFreeHeap [77f40000+156b+ff] 77f41d1c: ntdll!RtlpUnWaitCriticalSection [77f40000+1bfe+11e] 77d36441: USER32!MessageBoxTimeoutW [77d10000+263e8+59] 77d36529: USER32!MessageBoxTimeoutA [77d10000+264ba+6f] 77d364b6: USER32!MessageBoxExA [77d10000+2649d+19] 0012eb2c: 0012eb2c 77d3649a: USER32!MessageBoxA [77d10000+26476+24] 005285a6: MyError::post() 0048f5a8: VDProject::RunOperation() 0056f777: _NLG_Return() 00566cdb: _CallCatchBlock2() 0056f431: CallCatchBlock() 0056f39e: CatchIt() 0056f140: FindHandler() 0056efd4: __InternalCxxFrameHandler() 00566c86: __CxxFrameHandler() 77f69ba4: ntdll!RtlConvertUlongToLargeInteger [77f40000+29b3d+67] 77f69b78: ntdll!RtlConvertUlongToLargeInteger [77f40000+29b3d+3b] 77f50bf4: ntdll!CsrCaptureMessageString [77f40000+10a8b+169] 77f41d1c: ntdll!RtlpUnWaitCriticalSection [77f40000+1bfe+11e] 77f41dc9: ntdll!RtlpUnWaitCriticalSection [77f40000+1bfe+1cb] 77f41ec8: ntdll!RtlpUnWaitCriticalSection [77f40000+1bfe+2ca] 77f4166a: ntdll!RtlFreeHeap [77f40000+156b+ff] 77f41d1c: ntdll!RtlpUnWaitCriticalSection [77f40000+1bfe+11e] 77fa4dbd: ntdll!KiUserExceptionDispatcher [77f40000+64daf+e] 77e53887: kernel32!RaiseException [77e40000+13837+50] 77e53887: kernel32!RaiseException [77e40000+13837+50] 77f45266: ntdll!RtlConvertSidToUnicodeString [77f40000+50af+1b7] 77f43d99: ntdll!RtlValidSid [77f40000+3d5a+3f] 77f45266: ntdll!RtlConvertSidToUnicodeString [77f40000+50af+1b7]
-- End of report |
