An Error Message, AN ERROR MESSAGE
TOMIE10
Posted: Sep 13 2003, 02:52 PM
sad.gif PLEASE SOMEONE HELP ME.
I DONT KNOW WHAT TO DO MORE THEN I HAVE DONE.
WHEN I WANT TO SAVE MY FILM AS AN AVI,
IM GETTING AN ERROR MESSAGE THAT NO DEBUG SOURCE FILE WAS FOUND.
WHAT CAN I DO??
THANK YOU SO MUCH FOR YOUR HELP.
I DONT SPEAK ENGLISH THAT GOOD SO IM SORRY IF I DIDNT EXPLAINED MYSELF THAT WELL..
HOPE FOR A RESOLUTION...
Pamel
Posted: Sep 13 2003, 04:05 PM
matroska team member
This is not enough information to help you. Please get the following pieces of infomation.
1. Does it happen with all video files?
2. What version of VirtualDub and/or VirtualDubMod are you using? (The version number is in the top bar)
3. If you are using VirtualDub, does it also happen if you are using VirtualDubMod, or viceversa?
4. If saving a file in VirtualDubMod, does it have the same problem if you save to AVI, OGM, or MKV?
5. Does it make any difference if you select a different Video/Audio codec as the compressor?
6. Go to File -> File Information and copy all of the information into the post.
7. When exactly does the error/problem occur? Openning the file? When you click the Save button? Partway through the save process? At the end of the save process?
8. What Operating system are you using?
TOMIE10
Posted: Sep 13 2003, 04:34 PM
QUOTE (Pamel @ Sep 13 2003, 10:05 AM)
I HAVE AN AVI MOVIE AND I WANT TO WATCH IT ON MY DVD.
I WAS TOLD TO DO SOME THINGS:
1- FILE ---OPEN VIDEO FILE
2- VIDEO --- DIRECT STREAM COPY
3- AUDIO --- FULL PROCCESING MODE
4- AUDIO- --CONVERSSION
5- CHOOSE COSTUME AND WRITE 40000
6- FILE--- SAVE AS AVI
AND THATS WHEN I GET MY ERROR MESSAGE!!!
IM USING "VIRTUALDUB-MP3-FREE" BECOUSE IN THE OTHER VERSIONS I GET AN ERROR MESSAGE AT THE BEGINNIG, SOMETHING WITH MY AUDIO...
Pamel
Posted: Sep 13 2003, 05:17 PM
1. Download VirtualDubMod and us it. When it asks you if you want to correct the audio, tell it no.
2. Do not change the audio to 40,000. Perhaps 44,100 would be better?
Cyberman
Posted: Sep 13 2003, 09:36 PM
And please, next time - DONT WRITE IN CAPS! That´s considered yelling and bad art.
Matroska/MKV ?
4 replies since Sep 13 2003, 02:52 PM Track this topic | Email this topic | Print this topic
