Cannot Save Any Image Sequence, error " cannot open file "". "
Morsa
Posted: Aug 11 2003, 10:04 AM
This happens to me with 1.5.1.1a and the latest version 1.5.4.1.
I was hoping to fix it by myself but I don't understand what I'm doing wrong.
The same thing happens no matter what image format I choose........I was so happy with PNG sad.gif
Belgabor
Posted: Aug 13 2003, 05:02 PM
Developer of VirtualdubMod
Group: VirtualdubMod Team
Sorry, I replied to your pm before reading this. Could you give me a screenshot of a failing save image sequence dialog please?
[VirtualDubMod Homepage]
Please submit any bugs/patches/feature requests also using the respective tracker on our sourceforge page
Morsa
Posted: Aug 13 2003, 09:31 PM
Well take note it is in spanish.
It is a classic windows error message window.
It says: cannot open file "".
And below it says: La ruta de acceso especificada no es valida.
(the specified path is not valid)
Morsa
Posted: Aug 14 2003, 10:55 PM
I've been making more tests and this problem occurs on every Win98 machine I use.
It isn't related with the source video format.
VdubMod isn't crashing.It continues working properly except that doesn't let me save image sequences.
Need something else?
P.S:I didn't post a screeshot because it is a little embarrassing for me at this moment and because the only text that appears is the one i posted.
Thanks.
Morsa
Posted: Aug 15 2003, 06:06 AM
apart from my problem trying to save image sequences here is one of the so many crashes I'm having since migration to Vdubmod based on Vdub 1.5.
VIRTUALDUBMOD provocó un error de página no válida en el
módulo KERNEL32.DLL de 0187:bff7b9f6.
Registros:
EAX=022d15c0 CS=0187 EIP=bff7b9f6 EFLGS=00010202
EBX=ffffffff SS=018f ESP=00860000 EBP=00860028
ECX=0095fba8 DS=018f ESI=00000001 FS=8207
EDX=00000001 ES=018f EDI=819ca154 GS=0000
Bytes en CS:EIP:
,02x ,02x ,02x ,02x ,02x ,02x ,02x ,02x ,02x ,02x ,02x ,02x ,02x ,02x ,02x ,02x
Volcado de pila:
,08x ,08x ,08x ,08x ,08x ,08x ,08x ,08x ,08x ,08x ,08x ,08x ,08x ,08x ,08x ,08x
This is happening with an avisynth script, needless to say most of the crashes take place in conjunction with avisynth's scripts.
Thank you.
Posted: Aug 16 2003, 07:22 PM
@Belgabor:
Morsa sent me a PM about the "save image sequence" problem, I guess because I'm also on Win98SE. I was bored today so I downloaded VirtualDubMod 1.5.4.1 to see if I could reproduce it. I got the same error message trying to save any kind of image sequence. There is a screen shot here.
Morsa
Posted: Aug 28 2003, 12:55 AM
does anything happen with this bug?
Suiryc
Posted: Sep 4 2003, 12:28 PM
Can you save to bmp files with VirtualDub under Win98SE ?
[EDIT]
No matter. I was able to reproduce the bug here (had to cheat a bit in the source code to reproduce what happens under Windows 9x/Me).
Will fix that ASAP.
[EDIT2]
Fixed.
Morsa
Posted: Sep 4 2003, 11:47 PM
Thank you very very much, Suiryc.
So I guess there is a new binary.
Suiryc
Posted: Sep 5 2003, 05:04 PM
The version here should fix your problem.
9 replies since Aug 11 2003, 10:04 AM Track this topic | Email this topic | Print this topic
