| qkowlew |
Posted: May 26 2003, 03:59 AM |
Running VirtualDubMod (VirtualDubMod_1_5_1_1a_all_inclusive.zip 1699179 )
I see this strange picture:
I work under Windows NT 4.0 SP6a. All right in Win 2000.
Sergej Qkowlew, FIDO 2:5020/122 |
| Belgabor |
| Posted: May 28 2003, 07:53 PM |
Developer of VirtualdubMod
Group: VirtualdubMod Team
Hard to check without NT. Could you do us a favour and check the older versions of vdubmod and see if they work? thanks.
| Posted: May 29 2003, 06:37 AM |
Hmm... this looks vaguely familiar to a bug I fixed in the 1.4 series. If you define WINVER to 0x0500 or higher (Windows 98+), the MENUITEMINFO structure grows in size. Neither Windows 95 nor NT4.0 like the increased cbSize value and will fail menu API calls when they see it. |
| Belgabor |
| Posted: May 30 2003, 02:16 AM |
I knew I had seen this somewhere. What did you do to fix it? Redefine WINVER? Are there any other consequences to that?
| Posted: May 30 2003, 02:43 AM |
| CODE | #define WIN95_MENUITEMINFO_SIZE (offsetof(MENUITEMINFO, cch) + sizeof(UINT))
Should be the same as sizeof(MENUITEMINFO) with WINVER < 0x0500. If there are consequences to this, I'm screwed, because I'm still shipping releases with this.... |
| Belgabor |
| Posted: Jun 1 2003, 11:26 PM |
Thanks Avery, I'll try if it fixes the problem (at least it doesnt seem to break obvious things )
| Belgabor |
| Posted: Jun 4 2003, 05:47 PM |
Please check the latest CVS release to see if the bug's gone.
| AndreasB |
| Posted: Jun 13 2003, 03:15 PM |
I had the same problem like qkowlew with NT4, since VirtualDubMod 1.413.
Now, with the CVS-Version (1.5.1.1a build 1631/release) it's gone! Nice work! Thank you _VERY_ much for this great piece of software! :-)
Andreas
