| Sarreq Teryx |
| Posted: May 16 2003, 04:33 AM |
VirtualdubMod Alpha tester
I get the following error message loading AVIs into VDMod 1.5.1.1a
"This application failed to start because MSVCRTD.dll was not found. Re-installing the application may fix this problem."
or a copy of MSVCRTD.dll will too, which I'm sure I had but seems to be missing now. does anyone know where to find a copy?
| Sarreq Teryx |
| Posted: May 16 2003, 04:41 AM |
I just narrowed it down, it's DivX3 causing the problem, I have no idea why either, since it's being decoded by ffdshow
| Sarreq Teryx |
| Posted: May 16 2003, 04:45 AM |
or actually it'd be ffvfw decoding for VDMod, wouldn't it, anyway, like I said before, does anyone know where to get a copy of that file?? it'd be so nice if MS made a package of all these REQUIRED files themselves.
| Posted: May 16 2003, 05:13 AM |
Somehow I have that file (though I'm pretty sure it didn't come with Windows). Send me a PM with your email address and I can mail it to you.
| ChristianHJW |
| Posted: May 16 2003, 01:49 PM |
Sarreq, it seems you are using a debug build of VdubMod ? Did you compile it yourself ?
The file you need is the debugger DLL coming with VC6++ ......
| Suiryc |
| Posted: May 16 2003, 10:45 PM |
Developer of VirtualdubMod
Group: VirtualdubMod Team
| QUOTE (ChristianHJW @ May 16 2003, 07:49 AM) | Sarreq, it seems you are using a debug build of VdubMod ? Did you compile it yourself ?
The file you need is the debugger DLL coming with VC6++ ...... |
Not necessarily. This problem can come from any component that the program triggers (this can be a codec, a dll - such as AviSynth - etc). If he had compiled the program himself he wouldn't have problems running it (since that means he would have all the necessary files).
