| Menion |
| Posted: Feb 16 2003, 11:10 AM |
Hi, I'm using the 31/01/03 build. If you create a OGM file, the result file is corrupted. If you try to open there are two possibility 1) Crashes the explorer 2) Plays only the first second You can correct this re-opening the result ogm, ad re- saving using Direct stream copy both for video and audio, setting the second audio to "No Audio". I notice that saving an ogm file, the audio stream is directed to the second stream. Bye!
| Suiryc |
| Posted: Feb 18 2003, 11:43 PM |
Developer of VirtualdubMod
Group: VirtualdubMod Team
How did you made the OGM ? Did you used the Audio/Audio2 menu or only the 'OGM -> Show inputs' feature ?
It seems there are some bugs when using Audio/Audio2 (especially when using a preload that generally isn't a good thing for OggDS which freeze often).
| Menion |
| Posted: Feb 19 2003, 12:52 PM |
I used 'OGM -> Show inputs' feature. The ogg audio file was made with CDeX 1.50 latest beta. I edit the whole movie before encoding (cut some pieces...). Bye! |
