Network Render, Does it really work ?
DigitalVideo
Posted: Jan 8 2003, 10:44 PM
I don't know if I'm doing something wrong, but I can see my 2 PSs on the same net, 2 copies of VirtualDubMod are running, using Update both are visible, but remote rendering doesn't work for me.
Win2000 on Master and WinXP on Slave, same problem reversing M/S.
Max
Neo Neko
Posted: Jan 8 2003, 11:12 PM
VirtualdubMod Alpha tester
You must have the same codecs avalible and the video sources must be able to be located via the same path for best results. So you could either coppy the video files to the c:\ drive of both PCs or some such. Or you could share the directory containing the video files on the network and map that share to the same drive on each PC. Like drive Z:. That way you can always get to the video by going to drive Z: no matter what PC you are on.
DigitalVideo
Posted: Jan 9 2003, 06:32 AM
No way, even with the same file at the same location, on Master i can see:
PC1 Slave
PC2 Localhost (Master)
but on PC1 I see:
PC1 Localhost (Slave)
PC2 Not connected
Any help please ?
DigitalVideo
Posted: Jan 9 2003, 03:17 PM
Just done a new test at office, same problem, only master starts render, on Slave it seems that master PC is available but disconnected.
Max
jcsston
Posted: Jan 10 2003, 10:42 PM
Matroska Dev
I had this problem at first. Start up the Slaves first and the Master last.
It sometimes seems very picky of the order that m/s are started up
Use the Matroska file format
Vjetnam
Posted: Feb 5 2003, 08:37 AM
I have same problem. I testng it on 5 machines. All working on WIN2000.
I run slaves on 4 machines and then run master. Sometimes master connect to one machine anytime to 2, anytime to none. What happens?
Can help me anyone ?
BTW: I try also add IP into hosts.conf with no reason.
5 replies since Jan 8 2003, 10:44 PM Track this topic | Email this topic | Print this topic
