| Ingolf |
| Posted: Sep 28 2002, 08:16 PM |
Hi
Would it be possible in a future release to set the processing priority for all waiting jobs? I have some software that i schedule to automatic start and stop recordings, and if vdub 's processing priority is set to normal, or above.. the recording program will start losing frames. Besides that, when set to 'idle' everything works perfect.
You can set the priority when vdub is running, but when the next job is started, the priority is reset.
Btw.. im new here.. great that vdub finally got its own forum. |
| ChristianHJW |
| Posted: Sep 28 2002, 09:21 PM |
You can edit Vdubs default priority in the 'options' menu ...
| Ingolf |
| Posted: Sep 30 2002, 08:21 PM |
DOH! didnt see that.
Thanks |
