When I Do Play Back It Does This
yugioh_advance_84@yahoo.com
Posted: Apr 15 2014, 10:30 PM
hi there, i have issue that when i play back on virtualdub this attends to go a little bit off the screen, or doesn't playback on the picture doesn't show on the right when i preview it.
https://www.flickr.com/photos/123380562@N02...02/13881835653/
the the picture that i am showing you. so you can fix this problem right?
Posted: Apr 16 2014, 08:13 PM
1) If you only have this phenomenon with this particular AVI then I should suspect the video itself.
2) If you also have this phenomenon with other AVI's encoded with identical codec (DivX, Xvid, H264, ...) then I should suspect the actual decoder.
In this case, try to open the AVI with another decoder by using the FFMpeg or the DirectShow plugin for VirtualDub.
Please read following thread for more info on how to download and install these plugins:
> http://forums.virtualdub.org/index.php?act...=ST&f=3&t=22267
The preview window at the left normally shows the original video, the preview window at the right shows the video after filters have been applied.
So, if no filters are applied, the preview in these windows should be exactly the same.
If one or more filters or adaptation of colors are being applied, the preview at the right can be different in comparison with the one at the left.
You can always verify which filters are active via Video > Filters... and whether changes in colordepth are applied via Video > Color Depth...
Posted: Apr 20 2014, 12:15 PM
it's not the video Abrazo. i've tryed all the video files on virtualdub. still... it's virtualdub it self. the prevouse virtualdub didn't do that. all of the video files are fine. when i play back on virtualdub it shifts to right corner.
Posted: Apr 20 2014, 12:41 PM
You might want to use an image host that doesn't require registration - I'm not registering just to see a picture and I guess I'm not the only one who doesn't want to
Posted: Apr 20 2014, 02:05 PM
also the video on the right preview also is black is not showing. it's not that i need plugins, i have them. this problem has to virtualdub it self.
i have version 1.1.0.5 beta 4 virtualdub.
Posted: Apr 20 2014, 02:41 PM
In the options untick all the directx checkboxes
menu->options->preferences->display
see if that helps
Posted: Apr 20 2014, 02:47 PM
ps here's a better free image host
http://postimg.org/
(If you upload images, please upload them unresized)
Posted: Apr 20 2014, 08:27 PM
image host has nothing to do with video/audio files dloneranger. i'm trying to have the virtualdub developer fix the program with the video shift's to the corer of the scren. also the preview doen't show the picture when playing a video/audio. also avoid tearing (enable vsync) has a bug in that also. please fix avoid tearing (enable vsync).
Posted: Apr 20 2014, 09:30 PM
It matters if we can't see your posted images - you might as well not bother otherwise
Did you try disabling the directx options or not?
[edit]
You know what, I can't be bothered to help
Posted: Apr 21 2014, 10:55 AM
@dloneranger
Thanks for trying to help.
Myself I had no problem to open that picture (on flickr) showing the problem.
A direct link to it: http://farm8.staticflickr.com/7326/1388183...090e3ffaf_h.jpg
@yugioh_
If you do not have this problem with previous versions of VirtualDub, then probably Phaeron will be one of the few people who can tell what matters...
Posted: Apr 22 2014, 12:27 AM
i already had directx disable. that wasn't it. this was the problem i'm having
that's option i'm talking also if you read my last post. that's option needs to be fixed.
Posted: Apr 22 2014, 07:03 PM
OK. Now it is clear to me what you mean:
When the parameter "Avoid tearing (enable vsync)" is checked in VirtualDub 1.10.x via Options > Preferences... > Display,
then when playing the video (= NOT preview, but really "play" via the Input playback button) then (everyway at my computer)
the upper +/- 10% of the image is missing.
If that same parameter is NOT checked, then the image is correct.
This problem is NOT there in VirtualDub 1.9.11.
Posted: Apr 25 2014, 06:40 PM
Jeroma
Posted: May 7 2014, 07:50 AM
fast weight loss pills, how to lose weight, slimming pills,cha de bugre
13 replies since Apr 15 2014, 10:30 PM Track this topic | Email this topic | Print this topic
