Req: Separate Dialog Paths For Load Avi, Save Avi, and Load/Save configuration script
4N4
Posted: Jun 22 2012, 04:17 PM
VirtualDub only remembers a single path for save operations and one for load operations, so if I do Load AVI followed by Load config script, the dialog opens at the path where I opened the AVI.
- It would increase usability if separate paths were stored for Load AVI, Save AVI and Load/Save configuration script.
- If a path is stored for Load AVI but not Save AVI, the path for Load AVI should be used when doing Save AVI (and vice versa if it's stored for Save AVI but not for Load AVI).
- If a path is not stored for Load/Save config script, you could either use the Load AVI or Save AVI stored path, or just use the default current folder path. After this, the stored script/config path should be used.
0 replies since Jun 22 2012, 04:17 PM Track this topic | Email this topic | Print this topic
