Using Multicore With Queued Jobs, feature proposition
orca
Posted: Jan 5 2012, 06:30 AM
i understand that properly using multicore with same job is not trivial.
but if there are several jobs queued (several interdependent files) than utilizing multicore proc in such a way that each core processes a different task should be not that complicated.
freedomdwarf
Posted: Jan 6 2012, 08:50 PM
I don't have any problems running my multicore on a single job or with a job queue.
VD job control does one job at a time sequentially, it does not load each job into a different core to process independantly.
What did you expect it to do??
Posted: Jan 6 2012, 09:00 PM
It's usually the encoders multithreaded'ness that's a governing factor
Also, virtualdub can do this already
With the /master and /slave options you can run virtualdub multiple times on 1 pc (or spread over a network of pc's) all working their way trough a job queue
2 replies since Jan 5 2012, 06:30 AM Track this topic | Email this topic | Print this topic
