| reandr |
| Posted: Oct 3 2011, 08:15 PM |
i tried to build virtualdub 1.9.11 source on visual studio 2010 with windows sdk 7.0a and Microsoft DirectX SDK (June 2010).
solution conversion from 2008 to 2010 is ok. but the conversion is incomplete.
when build, much error occurred. almost errors maybe come from virtualdub build path related issues. and copied missing qedit.h from 6.1 sdk.
after many manual fixing , build was ok except for only one final problem.
1>------ Build started: Project: Riza, Configuration: Release Win32 ------ 1> cap_dshow.cpp 1> To compile qedit.h you must install the DirectX 9 SDK, to obtain the dxtrans.h header. 1>C:\Program Files\Microsoft Visual Studio 10.0\VC\include\utility(163): error C2664: '`anonymous-namespace'::VD_MSCOMAutoPtr<T,T_IID>::VD_MSCOMAutoPtr(const `anonymous-namespace'::VD_MSCOMAutoPtr<T,T_IID> &)' : cannot convert parameter 1 from 'int' to 'const `anonymous-namespace'::VD_MSCOMAutoPtr<T,T_IID> &' 1> with 1> [ 1> T=IMoniker, 1> T_IID=& _GUID_0000000f_0000_0000_c000_000000000046 1> ] 1> Reason: cannot convert from 'int' to 'const `anonymous-namespace'::VD_MSCOMAutoPtr<T,T_IID>' 1> with 1> [ 1> T=IMoniker, 1> T_IID=& _GUID_0000000f_0000_0000_c000_000000000046 1> ] 1> No constructor could take the source type, or constructor overload resolution was ambiguous 1> C:\Program Files\Microsoft Visual Studio 10.0\VC\include\utility(247) : see reference to function template instantiation 'std::_Pair_base<_Ty1,_Ty2>::_Pair_base<_Ty,VDStringW>(_Other1 &&,_Other2 &&)' being compiled 1> with 1> [ 1> _Ty1=`anonymous-namespace'::IMonikerPtr, 1> _Ty2=VDStringW, 1> _Ty=int, 1> _Other1=int, 1> _Other2=VDStringW 1> ] 1> source\cap_dshow.cpp(1639) : see reference to function template instantiation 'std::pair<_Ty1,_Ty2>::pair<int,VDStringW>(_Other1 &&,_Other2 &&)' being compiled 1> with 1> [ 1> _Ty1=`anonymous-namespace'::IMonikerPtr, 1> _Ty2=VDStringW, 1> _Other1=int, 1> _Other2=VDStringW 1> ] 2>------ Build started: Project: VirtualDub, Configuration: Release Win32 ------ 2> Assembling: a_bitmap.asm 2> Assembling: a_chromasmoother.asm 2> Assembling: a_convertout.asm 2> Assembling: a_histogram.asm 2> Assembling: a_scene.asm 2> Assembling: a_yuv422torgb.asm 2> Assembling: a_mjpgdec.asm 2> Assembling: a_yuv2rgbhq.asm 2> Assembling: a_yuvtable.asm 2> Assembling: a_brightcont.asm 2> Assembling: a_cmult.asm 2> Assembling: a_convolute.asm 2> Assembling: a_grayscale.asm 2> Assembling: a_reduce.asm 2> Assembling: A_resize.asm 2> Assembling: a_rotate.asm 2> Assembling: a_sharpen.asm 2> Assembling: a_threshold.asm 2> Assembling: a_tv.asm 2> Assembling: a64_resize.asm 2>LINK : fatal error LNK1181: cannot open input file 'D:\VirtualDub-1.9.11-src\lib\Release\Riza.lib' ========== Build: 0 succeeded, 2 failed, 11 up-to-date, 0 skipped ========== |
| reandr |
| Posted: Oct 3 2011, 08:40 PM |
hmm , i `v read now old thread about this issue. and found solution. just add (IMoniker *) to NUL in cap_dshow.cpp now build ok, finally i got virtualdub. =====================
mAudioDevices.push_back(tDeviceVector::value_type((IMoniker *)NULL, VDStringW(fi.achName)));
and successfully compiled new 1.10.1-test12 also( resolved some link issue(/MT))
1.9.11 AND 1.10.1 screenshot
