| led |
| Posted: Feb 18 2003, 01:46 PM |
Is it big change to add checkbox (and processing) to window "Save Image Sequence..." witch allows to save images reverse order. Now it is so that first image is xxx0.bmp and last is xxxN.bmp. My idea is that first image is xxxN.bmp and last is xxx0.bmp
It is easy way to convert video to reverse order. Or do you know another way?
Thanks, Linnar |
| ChristianHJW |
| Posted: Feb 18 2003, 02:56 PM |
You could only do this with uncompressed RGB Video, else you would screw the codecs, even HuffYuv ....
| Posted: Feb 18 2003, 04:28 PM |
Avisynth has a "Reverse()" command.
| Kippesoep |
| Posted: Feb 18 2003, 06:00 PM |
| QUOTE (ChristianHJW @ Feb 18 2003, 03:56 PM) | | You could only do this with uncompressed RGB Video, else you would screw the codecs, even HuffYuv .... |
This would only affect file naming, not actual order of decoding... |
| led |
| Posted: Feb 19 2003, 10:03 AM |
Yes, Kippesoep, you are right. This affects only file names. Then from menu "Open Video" will assemble BMPs back to video (backward).
Thanks, Linnar |
