| plamengv |
| Posted: Dec 28 2010, 11:17 PM |
1. Right now when you cut footage in VirtualDub there is no visual representation of the cutting points. I believe that it will be very useful to add either zebra type color change at each cut point or put some dot/arrow signs above or below the timeline. I mean that there is no visual representation after you cut some part! The piece that has been removed should by shown using some kind of mark to know that exactly on that point you have removed something. I can even see it developed further by adding the UNDO cut option as hint directly on that place mark! 2. The buttons to jump back and forward at the key frames are very useful but while using them I often press on buttons I never use (those for scene change). It will be great to put some interval between the different groups of buttons or even have the option to remove buttons from the UI. 3. Considering point 2, I can see some usage for a buttons that play not to the previous/next scene change, but to the previous/next cut points. 4. Going further with the buttons, there can be a button called R which can switch on/off repeating of either the whole video or a part between two cut points or two scene changes. 5. I have hard time to stop the video playback when I wrongly hit on the scene change buttons, I hit interval and video playback still continues. Can't be sure if it is a bug or something else.
Thank you for both considering my suggestions and the great software. |
| loin2kolpotoru |
| Posted: Mar 24 2013, 04:51 AM |
I have a UI suggestion please add a pause button while processing video. |
