| Jam One |
| Posted: Aug 19 2009, 09:23 PM |
Happening to get 102% NTSC wide color gamut display made me think of "color management for video" in Virtual Dub.
For the pictures it's OK with ACDSee Pro, Firefox 3.5, CorelDraw etc. TV-tuner image also looks brilliant. But VD doesn't =)))
Videos can be played back with perfect sRGB color match by MediaPlayerC.-HC with use of custom pixel shader. I made a pixel shader in accordance with instructions from over there: http://forums.overclockers.com.au/showthre...ad.php?t=723315
Virtual Dub can use D3D.fx files to get preview video processed by shaders.
My questions are:
1) Is there an easy way to make d3d.fx file with the MPC-HC shader ? (given I'm positively not a programmer|software developer=))
| CODE |
sampler s0 : register(s0); float4 p0 : register(c0);
static float4x4 r2r = { 0.65165101527372,0.339654590429908,0.00869439429637275,0, 0.0369531141567577,1.00093150831362,-0.0378846224703816,0, 0.010201491434332,0.0189330342932091,0.97086547427246,0, 0, 0, 0, 0 };
float4 main(float2 tex : TEXCOORD0) : COLOR { float4 c0 = tex2D(s0, tex); c0 = pow(c0, 2.2); c0 = mul(r2r, c0); c0 = saturate(c0); c0 = pow(c0, 1/2.2);
return c0; }
2) Would it be possible, at least in the future, to implement "Colorspace awareness" feature in VD that would read the default display icm color profile and adjust preview panes accordingly ?
This post has been edited by Jam One on Aug 22 2009, 04:34 PM |
| Posted: Aug 20 2009, 04:34 AM |
MPC/MPC-HC shaders can be run unmodified on the CPU through VDShader 1.2: http://www.virtualdub.org/downloads/vdshader-1.2.zip
This is a decently heavy shader. It's taking about 30% of one core on my 2.5GHz Core 2 at 640x360, 24 fps.
In order to run it as a display shader, it needs some modifications:
| CODE | extern sampler s0 : register(s0);
return c0; }
void VS(float4 pos : POSITION, float2 uv : TEXCOORD0, out float4 oPos : POSITION, out float2 oT0 : TEXCOORD0) { oPos = pos; oT0 = uv; }
texture vd_srctexture;
technique { pass { VertexShader = compile vs_2_0 VS(); PixelShader = compile ps_2_0 main(); CullMode = none; AlphaBlendEnable = false; Texture[0] = <vd_srctexture>; AddressU[0] = clamp; AddressV[0] = clamp; MinFilter[0] = linear; MagFilter[0] = linear; } }
There are a couple things I'm confused on, though.
First, what exactly are your source and target color spaces here?
Second, are you sure you want a straight 1/2.2 curve? sRGB/scRGB, as far as I know, use a 1/2.4 power curve with a linear section. |
| Dstruct |
| Posted: Aug 20 2009, 07:32 AM |
Wouldn't it be much easier for the user to be able to select a monitor profile (*.icc) and let VirtualDub do the rest? |
| Posted: Aug 21 2009, 04:46 AM |
VirtualDub ignores monitor profiles since it uses DirectDraw/Direct3D. Besides, I'm not sure how easy it is to configure a custom monitor profile. |
| Jam One |
| Posted: Aug 22 2009, 05:31 PM |
First of all, thank you very much, phaeron, for your help, I am a lot grateful to you! The shader works. Pardon my delayed answering, I was checking everything several times.
Now it's clear that VirtualDub is in the not-so-big-yet company of high-grade professional programs capable of working on wide-gamut displays.
How did I do checking:
Synthetic "ColorBars" test video was generated with AviSynth, a frame of it exported in form of BMP. Several photo images and frames exported from real videos were opened in ACDSeePro with color management set to treat untagged images as sRGB (default Windows profile and also the reference sRGB profile with blackpoint compensation, taken from here: http://www.color.org/profiles.xalter) ; Amongst images were some of the photographic test pictures, like: http://www.imaging-resource.com/PRODS/DMCG...SLI0100_NR3.HTM Images were also opened in CorelDraw (with its own color management engine)(for double-check purposes). Videos and photos were also being opened in MediaPlayerClassic - Home Cinema and in Virtual Dub.
As a result of all the fun, there is no visible difference between the look of VirtualDub and CorelDraw/ACDSeePro (with black-point corrected sRGB profile). There is, allegedly, some microscopic difference with certain videos between looks of the latter applications and MPC-HC in mid-dark tones. At this very moment I tend to think that "maybe Virtual Dub knows better how to decode those videos" (also, I have little knowledge of how exactly VMR9 acts, so I can blame some deviations on its implementation).
About the spreadsheet:
"Your display xy" cells should be filled with x,y coordinates of the display's profile. Not with X,Y,Z. Since my goal was to have emulation/color-proofing for sRGB monitors, I changed/overwrote BT-709 cells with coordinates of Windows-default sRGB IEC61966-2-1 profile. Coordinates are also x,y for RGB primaries and for the Whitepoint.
| CODE | sRGB IEC61966-2-1
R G B W x 0.648451 0.321199 0.155887 0.312699 y 0.33085 0.59784 0.06604 0.329001
z-coordinates are being calculated by Excel.
Regarding white-point, experiments show the best solution is to use sRGB's whitepoint for both input and output colorspaces. If we set our monitor's whitepoint as "output" we get what I believe is Absolute-Colorimetric Rendering Intent. Which I don't need. I'm sure. I don't need to look at yellowish images nobody will see - because not many users out there tune their monitors to 6500K. Total majority, I'm afraid, look everyday at 9300K or something like this. (My monitor is set to 7000K to match the ambient lighting/viewing conditions.)
About the source and target colorspaces: The target colorspace is the (custom) colorspace of the monitor. There're no standards for wide gamut displays, so... this colorspace can be defined either by the manufacturer's color profile supplied with driver, or by custom-profiling. I calibrated&profiled my monitor with hardware colorimeter, so, coordinates of my colorspace came from the "objective reality" (I hope and pray).
The source colorspace in my case is sRGB. Why? Because all I need at the moment is to Emulate/colorproof videos I'm going to edit over here and other people are going to watch over there on their sRGB monitors. I need to know what they will see. That's, actually, it. sRGB monitors are standard, well, at least to some extent, unlike the wide-gamut ones. Maybe I will calculate shaders for other source-colorspaces later, but now I'm going to feel myself happy for some days or weeks about being able to emulate sRGB, to squeeze the image-data back into the sRGB gamut triangle. (Yes, surely, of course, the monitor has got its own "sRGB emulation mode", but... but. But to switch it back-and-forth is not an ideal idea.)
About gamma curve:
Well, as far as I can understand, what we deal here with is not sRGB-gamma. According to the author of the method (http://www.avsforum.com/avs-vb/showthread.php?t=912720): | QUOTE | | In the PC, the RGB data we have is all at the non-linear domain (called R'G'B'), and the conversion between primaries should be done at the linear domain (called RGB). So, for performing the color correction, we have to convert from R'G'B'->RGB, apply the conversion matrix and then convert back from RGB->R'G'B' - our displays need R'G'B'. |
So, the gamma value to be used here is (have to be) the gamma of our display. Since (if) the display was calibrated/profiled to gamma=2.2 this value must be suitable for calculations. In other words, our task at some step is to suppress the curvature of display's gamma to let the linear correction work correctly. This gamma hardly has something to do with sRGB or any other colorspace in the world except the one of our monitor. The author himself makes a mistake proposing the gamma of BT-709 to be used. If you know this assumption is erroneous - I'm interested to know it too.
Thanks again!!! |
| Dstruct |
| Posted: Aug 22 2009, 05:46 PM |
| QUOTE (phaeron @ Aug 21 2009, 06:46 AM) | | VirtualDub ignores monitor profiles since it uses DirectDraw/Direct3D. Besides, I'm not sure how easy it is to configure a custom monitor profile. | I had something like this in mind:
-> let the user specify a icc file (the one you get from calibration) -> then with some pixel shader the colors should be adjusted by virtualdub to the screen (only to the screen!) according to the icc file
Not possible? |
| Posted: Aug 22 2009, 09:43 PM |
| QUOTE (Dstruct @ Aug 22 2009, 10:46 AM) | I had something like this in mind:
-> let the user specify a icc file (the one you get from calibration) -> then with some pixel shader the colors should be adjusted by virtualdub to the screen (only to the screen!) according to the icc file | Afraid I don't have any experience with ICC profiles, although Windows GDI does have some functions for dealing with them that could be usable for generating lookup tables. I believe there is a complication in that you have to tell GDI how to do the gamut mapping as well as which profile to use, since there are different algorithms that attempt to preserve saturation, preserve hue, etc.
Color compensation is something I haven't gotten very far in. Probably the first thing I'd do is just add some more test patterns, since I've noticed my external monitor has slightly whacked levels (it's connected via analog). |
| Loadus |
| Posted: Oct 22 2009, 10:35 PM |
Using the "max" gamut matrix (1.0 / 0) has the effect on colours that people usually seek in linear editing. Phaeron is correct about the gamma, the original CRT response was in the 2.4/2.5 realm. With the flat panels of today, it's getting pretty flat also at the dark end (true linearized CRT monitor looks twice as dynamic as LCD TVs of today - and I mean a CGI workstation CRT with 1.0 gamma, not 2.5)
I once asked about calculating the coefficients using a matrix from Phaeron, but I lost interest in fiddling around with the code. I'll probably tweak this a bit and post the CIE 1931 equivalent (that gives equal saturation to primaries and secondaries).
| Jam One |
| Posted: Oct 23 2009, 12:22 PM |
| QUOTE | With the flat panels of today, it's getting pretty flat also at the dark end ... |
- Do you mean non-gamma curve, like the one of sRGB, can describe it better than smooth gamma-curve ? |
| Loadus |
| Posted: Oct 23 2009, 01:23 PM |
| QUOTE (Jam One @ Oct 23 2009, 06:22 AM) | | QUOTE | With the flat panels of today, it's getting pretty flat also at the dark end ... |
- Do you mean non-gamma curve, like the one of sRGB, can describe it better than smooth gamma-curve ? | Well, the blackpoint is so high on flatpanels, that the black levels get washed away (I have Bravia myself, which has one of the deepest blacks on the market and it still loses a lot to my trusty CRT and my old TV monitor) : /
And I read on another post that you're only trying to get the VirtualDub's output to reflect the actual 709 colors, I was going for the workspace matrix - so my post might seem a bit "off". lol, sorry about that.
Also, you _will_ need a TV monitor with a proper TV out to view the colors when editing - Even proper Color Management won't give you the exact hue errors and gamma deviations and color gamma with approximated matrix values. You need to measure the screens and simulate with absolute/perceptual colorimetric to get close.
Which makes things a bit complicated.
Implementing Color Management to VirtualDub would probably be semi-simple with existing libs, but it would slow things down to a crawl.
| Jam One |
| Posted: Oct 23 2009, 04:01 PM |
Ah, thank you, Loadus!
...My intention was (it had been achieved, luckily) to get VirtualDub to emulate the sRGB color space on my Dell-2408... (To see the picture the way it is supposed to look on sRGB monitors.) I mostly edit videos to be viewed on PCs. |
| Loadus |
| Posted: Oct 24 2009, 03:28 PM |
I tweaked and I tweaked and I think I got it at least semi-right:
http://www.loadusfx.net/virtualdub/CIE%201...20Saturation.fx
Saturation booster that does it equally to Red, Yellow, Green, Cyan, Blue and Magenta.
The code might look ackward, but then again, I'm not a coder, I'm just a graphics designer. : /
EDIT:
Aaaand few seconds of tweaking reveal that the whitepoint is calculated WRONG. Back to the ole drawing board. >:(
EDIT Part deux: Alright, just uploaded the version with equal weights on primaries, should give you neutral whites .. I hope.
| Dstruct |
| Posted: Aug 24 2010, 09:29 AM |
Bit offtopic, but Media Player Classic Homecinema 1.3.2305.0 now has full color management built in (when using EVR-CP or VMR9 renderer): http://www.xvidvideo.ru/media-player-class...-cinema-x86-x64 |
| Dstruct |
| Posted: Oct 26 2010, 01:09 PM |
In Media Player Classic Homecinema they use Little CMS: http://www.littlecms.com
Maybe this could be used in VirtualDub too? |
| Posted: Oct 30 2010, 11:02 PM |
Odd. I always thought HC people were picky enough that they wouldn't be willing to sacrifice color precision to do color adjustment in the PC instead of on the display device. |
