Feature Request: Timestamp Filenames For Captures
play32
Posted: Mar 6 2006, 07:55 AM
For those of us scheduling video captures through the Windows Task Scheduler, it'd be great if the date/time could be automatically added to the capture filename, e.g. for recording a TV show that airs several times a day and/or several days a week.
Also, I thought autoincrement was supposed to avoid overwriting files as of 1.6.12 -- I'm using 1.6.13 and it is still overwriting whatever file I specify with the /capfile parameter.
Posted: Mar 6 2006, 08:25 AM
The autoincrement check for overwrites is in the GUI code, but unfortunately the /capfile switch bypasses the GUI and goes straight to the capture engine, so it doesn't do the check. Oops. Will fix for 1.6.14.
play32
Posted: Mar 6 2006, 08:58 AM
Thanks, that seemed like what was happening. Hope you'll still consider the timestamps as a possibly cleaner way of solving this problem.
isidro
Posted: Oct 11 2012, 07:17 PM
Just opened a thread about this bahaviour, I'm almost sure that there was a vdub version which incremented filename automatically in commandline, but latest (v1.10.2 and v1.9.11) overwrites without incrementing filename.
Posted: Oct 13 2012, 07:53 PM
/capfileinc bumps the filename until it's clear.
isidro
Posted: Oct 14 2012, 07:44 PM
It might be more intuitive to have only "/capstart" and use same bahaviour as when you manually capture: (Verify if "Autoincrement Filename" is checked or not in Capture menu)
Posted: Oct 21 2012, 08:54 PM
I could go both ways on that. The problem with options that affect command-line operation is that it can cause a batch file to succeed or fail depending on the GUI state. That's good if you're constructing the batch file by thinking in terms of the GUI, bad for consistency and if there isn't a command-line override.
6 replies since Mar 6 2006, 07:55 AM Track this topic | Email this topic | Print this topic
