Virtualdub 1.6.6
kurtnoise
Posted: May 30 2005, 06:11 AM
Moderator of the Vdub Support Forum
http://prdownloads.sourceforge.net/virtual....6.zip?download
Build 23486 (1.6.6, experimental): [May 29, 2005]
  [features added]
  * Added an option in Options > Preferences > AVI to force sector alignment
    for large uncompressed frames. This can resolve compatibility problems
    with some uncompressed hardware video playback units.
  [bugs fixed]
  * Capture: Video/audio format and compression and video frame rate now
    autosave on disconnect.
  * Capture: Fixed some cases where the Raw Audio Format dialog didn't
    highlight the currently selected PCM format.
  * Capture: Noise reduction threshold was not restored properly.
  * Capture: Renamed Peak Meter back to Volume Meter and restored V
    accelerator.
  * Frame byte size was being computed improperly for YCbCr AVIs.
  * Fixed broken MJPEG video decoding at bottom-right corner on streams that
    have restart markers.
  * Reworked MJPEG field ordering detection to be consistent with DirectShow
    MJPEG decoder. If this is reversed for your files, enable "swap fields"
    in AVI extended open options.
  * Scene detection was busted for 16-bit RGB (very rare case).
  * Minor status updating features, such as the current position nub moving
    during input preview, were broken after running a job that ended in an
    error.
  * (AMD64 only) Scene detection is now implemented.
  * (AMD64 only) Enabled some video filters that had scalar implementations:
    flipv, fliph, deinterlace, rotate, and HSV.
  * Save Image Sequence dialog didn't show the "add as job" button as checked,
    even if it was saved as such from the last time.
  * Fixed minor bugs in various image converters and improved accuracy of a
    few YCbCr-to-RGB converters.
  * Fixed UYVY/YUY2-to-RGB converters not interpolating chroma properly.
  * Fixed YVU9 chroma planes being swapped on write to disk and enabled YVU9
    for direct input.
  [regressions fixed]
  * App would sometimes exit after stopping frameserver.
  * Frameserver sent garbage data if the video filter chain changed the frame
    size.
  * Fixed a regression in video codec negotiation for MS MPEG-4 V3 variants
    where a different but compatible codec was not properly detected.
  * Doing a paste with no selection caused one frame to be deleted before
    doing the paste.
  * Write open failures were being reported again when the target file
    couldn't be opened a second time in fast I/O mode, which happens
    sometimes with emulators or remote drives. The slower fallback has been
    reinstated.
  * Running out of disk space at the very end of a render operation was
    sometimes reported as an I/O error rather than a write error.
  * Sampling in filter preview could fail if the timeline had been edited.
Visit the French United Video Forum : http://www.unite-video.com
Posted: May 30 2005, 06:43 AM
For the record, 1.7.0 is still being worked on, and I have renamed the topic to avoid confusion. smile.gif
1 replies since May 30 2005, 06:11 AM Track this topic | Email this topic | Print this topic
