Virtualdub 1.6.2 Released!, enjoy!
stephanV
Posted: Dec 14 2004, 03:22 PM
Changes for 1.6.2:
Build 22651 (1.6.2, experimental): [December 12, 2004]
[features added]
* Capture: Improved Unicode support.
* Capture: DirectShow video capture support.
* Capture: Enhanced volume meter.
* Capture: Alternate audio resampling mode for reduced
frame drops when resyncing.
* Capture: Audio compression now occurs after resampling
for better timing.
* Capture: Stop hotkeys are no longer system global.
* PNG images are now supported for read.
* AVI info tags are now supported.
[bugs fixed]
* Fixed occasional crash when using DirectX display mode
with 8-bit display.
* Appending type-1 DV AVIs caused the output AVI to have
the wrong stream type.
* Fixed rare junk displays when overlay playback is enabled,
caused by selection of overlay formats that the bitmap
library cannot support conversions to.
* Fixed source formatting tags in timeline strings
reporting huge frame numbers at the end of the timeline.
* Fixed garbage when attempting to convert Pal8 to Y8.
[regressions fixed]
* Fixed slowdown in shuttle commands.
* 24-bit video depth settings in configuration files saved
from 1.5.x were being imported as 16-bit.
* Fixed crash when switching to frameserver mode.
* Fixed crash when attempting to finalize AVI file after a
disk full or file size error.
* Fixed expression evaluation errors in scripting language.
* Fixed intermitted crash in Preferences dialog related to
enable links.
* Fixed crash when attempting to play 8-bit paletted AVI
files.
useful links:
i4004
Posted: Dec 14 2004, 09:02 PM
* Capture: Audio compression now occurs after resampling for better timing.
my signature:
ieremiou
Posted: Dec 16 2004, 05:42 PM
Awesome update, I love these tools.
Thanks you, stephenV for that link to Avi MUX GUI in your Signature.
I never knew about that tool but with that tool I was able to simply extract the compressed at it was audio file which allowed me to easily fix the audio problem with Adobe Audition. The audio was outputing only from the left speaker it was badly ripped I guess from an old VHS (Got it off of eMule several months ago but never could figure out how to fix it and get past the deadlock problems). Also AVI MUX GUI had the option to save the AVI file without any audio streams (kinda like VirtualDub but quicker in my opinion.)
So using AVI MUX GUI and Adobe Audition to fix the audio file and then I used virutaldub to splice them back together again (btw I dumped the avi file without the bad audio stream which usually gives you a better chance it getting a good file in my opinion) and it worked with no livelocks. Then I cut off a little of the beginning with VirtualDub and it worked perfectly. Thanks guys for these great tools! Whew. smile.gif
Tut_Ank
  Posted: Dec 20 2004, 04:13 PM
I get an error blink.gif with 1.6.2 when joining two avi files. I cannot append an avi file to another, both files that have the same video and audio format. When I join them using previous versions there is no problem. It worked with 1.5.10 using the same two files and I think it also did with 1.6.1.
Can someone move this Post to the bugs thread? sorry I replied here
Posted: Dec 21 2004, 04:48 AM
Actually this isn't that bad of a place for it.
I accidentally tripped over an old bug in the AVI code when I added tag support, causing the Append function to break. I'll fix it in 1.6.3.
bond
Posted: Dec 22 2004, 09:48 PM
hi, i always get a crash in user.exe when i start vd (shortly after this "beaware experimental" message shows up)
i have a pentium3 866mhz and winme (used 32bit compile)
5 replies since Dec 14 2004, 03:22 PM Track this topic | Email this topic | Print this topic
