Virtualdub 1.5.9 Is Out
kurtnoise
Posted: Nov 10 2003, 06:25 PM
Moderator of the Vdub Support Forum
Here's the change Log :
Current build (1.5.9, stable):
  [features added]
  * Made 'autodetect additional segments by filename'
    option sticky.
  * Removed trackbar ticks when ticks are a solid bar
    to speed up edits on very long timelines.
  * Added option to disable use of DirectX in video
    displays under Preferences/Display.
  [bugs fixed]
  * Fixed odd lock-to-keyframe behavior with edit lists
    that have out of order segments.
  * Fixed move-to-next-keyframe command at end of time-
    line.
  * Fixed decompression of 1-bit and 4-bit uncompressed
    AVI files under Windows 95/98.
  * Audio compression dialog showed the wrong set of
    valid formats if a precision was selected under
    Audio Conversion.
  * The current edit list is no longer applied to batch
    jobs created from entire directories.
  [regressions fixed]
  * Fixed display crashes with odd-width images.
  * Segment loading wasn't hopping across drives to pick
    up segments from a multisegment capture, as directed
    by the AVI's segment hint block.
http://virtualdub.org/
Visit the French United Video Forum : http://www.unite-video.com
0 replies since Nov 10 2003, 06:25 PM Track this topic | Email this topic | Print this topic
